customize self-registration portal using javascript
Isaac
Level 2
Level 2
we are trying to accomplish the following:
we are running into issue inserting the *OR* and space. has anyone ran into something like this? This is a client request.
pieterh
if you mean you have trouble with the "*OR*" then try first without the asterixes
if you mean you cannot create a space try if it works to create "invisible" fields to create space
