CW9166 Power Off CLI Command
madhurimuppalla
Is there any CLI command in CW9166 AP to Power off the Access Point ??
Mark Elsen
  = No APs do not offer that possibility
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Rasika Nayanajith
If AP is managed via WLC, you can turn off radios administratively (eg in a 9800 WLC#ap name <AP_NAME> shutdown).  If you want to power it off completely then upstream switch POE need to be turn off.
If turning off available with AP itself, you will lock it out yourself, cannot turn it on again unless manual intervention.
Rasika
*** Pls rate all useful responses ***
