Data path down and Control path is up on wlc
networklearner1
Hello All,
We have 2 WLC's.
5508- Anchor WLC (8.5.161.7)
3504- Foreign WLC (8.10.185.0)
I have created a mobility group and added the WLC's MAC respectively.
The FW ports 16666, 16667, 97 are all open.
The control path is UP but the Data path is DOWN. I tried removing the IP from group and adding again. Also tried rebooting the WLC's but it is still showing Down. Could someone please let me know how to fix this.
networklearner1
Hello All,
It seems the EtherIP traffic was getting denied in another firewall, we allowed it and then both the tunnels came up.
7 Replies 7
Mark Elsen
 - Have a look at https://community.cisco.com/t5/wireless/static-mobility-group-status-control-and-data-path-down/m-p/4713192#M247666
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
networklearner1
Thank you @Mark Elsen , I don't see any block or drop on our FW. Is there anything else that can be checked?
   - Well, to verify correct firewall behavior , examine (full)  logs and confirm allowed traffic for the involved ports ; (check that you can see the needed pass trough traffic). The response I pointed to in my initial reply also mentions :
                     https://mrncciew.com/2013/03/24/mobility-ping-tests/
  Have a go with that too , if that does not work for instance, again iterate on the firewall and check what it does with the intended traffic.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
what is the FW you have?
MHM
It’s Paloalto
I was hope it Cisco but anyway
try open port UDP
5246/5247
MHM
networklearner1
Hello All,
