09-13-2010 09:48 AM - edited 07-03-2021 07:10 PM
It's possible to configure WLC to advertise one SSID for a dedicated AP?
On WLC 2100 series are 16 SSID limited but how many on 5500?
Kamil
Solved! Go to Solution.
09-13-2010 10:42 AM
yes, you can shape what SSIDs you want on an AP to be used. Its call "ap groups". Yes, only 16 can be used on an AP at any one time, however you can configure up to 512 SSIDs in total on a WLC.
I did a video on ap groups here
http://www.my80211.com/cisco-wlc-labs/2009/3/22/cisco-ap-group-nugget.html
If you are using newer code AP groups config has changes slightly read more about it here page 6-49
http://www.cisco.com/en/US/docs/wireless/controller/6.0/configuration/guide/Controller60CG.html
Let me know if you need anything else...
please rate helpful post !
09-16-2010 03:16 PM
Thank you for the rating !
09-13-2010 10:42 AM
09-16-2010 03:16 PM
