Default SSID
Colin Higgins
Level 7
Level 7
I am setting up a controller to go into our existing environment. Our other controllers have a bunch of WLANs set up on them, all mapped to vlans on the switch, with their own SSIDs, keys, etc.
During the setup wizard, the 4400 wants to know the default SSID (Network name).
Can this be any SSID/WLAN? For instance, "OfficeData", mapped to WLAN/VLAN 235 that is trunked to the controller?
Stephen Rodriguez
absolutely! Usually though I create a dummy WLAN with base configs. The remove it and configure my real said once the WLC is fully up. I find that easier than mucking around in the wizard
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Stephen Rodriguez
Steve
HTH,
Steve
