Define WLAN ID for Cisco 9800 WLC using Prime Infrastructure
bhunt7
  I'm trying create a template to configure a WLAN on a 9800 WLC. I want the WLAN to have a specific ID. How can I set the WLAN ID in a template?
5 Replies 5
Scott Fella
If it’s not available in the template, then you can’t. Make sure that your PI supports the 9800 that you have.
-Scott
bhunt7
Scott,
 Thanks for the reply. I running ver 3.7.1 which does support the 9800. I'm able to push templates to apply wlan configurations but, I cant set the Wlan ID.
Scott Fella
If the option is not there, then that is something you need to either wait for or open a TAC case and suggest a feature request. You can always create the ssid on a controller, take the configuration for that specific ssid and then use a cli template to push that out to the 9800’s. That would be the workaround.
-Scott
bhunt7
Yes, I think I will need to open a TAC.
Scott Fella
Someone asked this same question not too long ago. Here is the thread, but you might just want to open a TAC case and see what they say.
https://community.cisco.com/t5/wireless-and-mobility/define-wlan-id-for-cisco-9800-wlc-using-prime-infrastructure/td-p/4026179
-Scott
