delay in authentication EAP client
ashish_gupta
Level 3
Level 3
hi
We have a client who has 4 APs on 1 floor which channels 1,4,7,11 with EAP-TLS enabled. The radius server is placed in u can say hongkong. The problem is
1. When a client starts a download, the client roams all the APs causing the download to make much more time. When this downloading is switched off it comes back to the nearest APs.
Any help is welcome
thanks
2. We are facing problems in getting clients authenticated. The ACU shows that the client has associated to a particular AP then it roams to all APs for a while and then randomly starts authentication with one AP and finally authenticates. The settingds in client side is clear channel assessment as firmware default.
The APs in question are 1100
paddyxdoyle
Level 11
Level 11
We have a similar set up with 3 1200 APs and an ACS radius/certificate server for EAP-TLS. All APs are configured with the same SSID and are all set to use a fixed channel (11). The APs and the ACU have all been upgraded to the latest firmware and it all works correctly. If you pick up a laptop and roam throught the building you can reathenticate from different APs without any problems.
Rgds
Paddy
