Deploying Multiple Wireless VLAN's
g.summers
Community Member
I am setting up a wireless network with about (40) 350 series access points. I want to set up 4 different wireless vlans with different security policies. What vlans would you put the switches, ACS server, WLSE and Access points in?
gamccall
Level 8
Level 8
A fifth one. The native vlan for the APs should be wire-side only; your four wireless SSIDs should each be mapped to a vlan other than the native.
