Design Controler 5508 & 5760 Compatibility - N+1
martinez.david2
Level 4
Level 4
I've 5508 WLC and adding a new 5760..
I know, it's possible for this 2 to be in the N+1 model (version 7.6)
If the 5508 or 5760 goest down, the AP previously associated to the failure controler, need to re-download the image to join the active controler.
Is it expected to change this constraint image reloading ? If yes, when ?
This is still a Cisco Validated architecture ?
Tks a lot.
Bye.
David
Rasika Nayanajith
Unfortunately these 5760 & 5508 AP images are not exactly same. So if fail-over occur AP has to re-download the image.
Yes, this has to be fixed, but not sure when.
Also there is no CVD for anything related to converged access, very bad indeed
Rasika
**** Pls rate all useful responses ****
