design for wireless project....need help....
azeemo157
Hi Team
i have a requirement from client and need suggestions on the design. Client has 1 main office and 5 remote branches. client requires wireless in all offices. approx 600 access points with 100 in each location client requires all wireless access points to be registered at HO controller and a redundant controller to be at the branch. if the controllet @ HO goes down access point to be served by the controller local to the site.
Is this type of a design possible ? kindly do help me in suggesting the best for my clent.
Thanks !!!
16 Replies 16
hi
I have 1 GIG bandwidhth between Remote site and HQ. The customer has laid fiber between each remote site to the HQ.
That should be okay... Just look at the current link utilization and make sure the added bandwidth will not affect certain applications or voice. But a gig link should be okay. You don't have any static ip devices do you? Because in a failover, those devices will not work assuming that it's L3 between HQ and the remote site. Client devices will have to be able to re-associate and renew their ip address also in order for your design to work. Sticky clients might require a manual renew in order to obtain a new dhcp address.
Scott Fella
Sent from my iPhone
-Scott
