Detecting noise levels with CB21AG-A-K9
kevin.willey
All,
Just purchased a CB21AG-A-K9. Downloaded the latest drivers from the web site. But, when using both the Cisco Site Survey Utility as well as Netstumbler, I am not getting noise levels reported. Nothing in the documentation seems to indicate that this card doesn't support RFMON mode, so why no noise levels reported?
PC host is running WinXP Pro SP2.
Thanks!
Kevin
ebreniz
Level 6
Level 6
Thanks for the reply. But saw that in the manual and already tried it. I see no noise levels even when "display in dBm" is selected.
