Device or resource busy error message on AP1100
juergenott
After a "copy tftp running-config" command an AP1100 was printing an error message and did not apply the commands in the downloaded file into the running config of the AP:
228004224752-1_4#copy tftp://172.28.27.248/test/fixedIP-10.0.64.1.cfg.25164 running-config
Destination filename [running-config]?
Accessing tftp://172.28.27.248/test/fixedIP-10.0.64.1.cfg.25164...
Loading test/fixedIP-10.0.64.1.cfg.25164 from 172.28.27.248 (via BVI1): !
[OK - 91 bytes]
%Error opening system:/running-config (Device or resource busy)
228004224752-1_4#
The AP runs on IOS 12.2.13JA4. The downloaded file contained:
interface BVI 1
ip address 10.0.64.1 255.255.255.248
exit
ip default-gateway 10.0.64.6
end
The idea of the tftp download was to modify the AP from DHCP to a fixed IP address.
What does this error message mean?
dixho
Level 6
Level 6
The running configuration is locked; so that the copy command cannot access running configuration. Please make sure that there is no other telnet session in configuration mode. Also, there is no HTTP session configuring the AP.
I use a similar command "copy ftp run" on an AP with 12.3(2)JA. It works fine for me.
dixho
Level 6
Level 6
Yes, thanks! The problem was a previous tftp download running at AP startup.
The downloaded file contained a command which was waiting for user response and the AP seemed to be still in config mode.
After modifying the command the subsequent tftp download worked fine.
