DHCP dropping packet due to ongoing mobility handshake exchange
networklearner1
Hello All,
we have our new mobility Anchoring setup. When we try connecting the client, the end user does not get IP.
below is the debug logs-
(Cisco Controller) >debug client c6:c7:a6:b5:2e:df
(Cisco Controller) >*emWeb: Jan 17 14:59:17.723: [PA]
Debugging session started on Jan 17 14:59:17.723 for WLC AIR-CT3504-K9 Version :8.10.185.0 SN :FCW2439K676 Hostname WLCANC-43-1
*radiusCoASupportTransportThread: Jan 17 14:59:41.197: [PA] processIncomingMessages: Received a message from server 10.147.15.43 of len 202 with reason code 0
*radiusCoASupportTransportThread: Jan 17 14:59:41.197: [PA] processIncomingMessages: received a frame with code 43 from 10.147.15.43 on port:57932
*radiusCoASupportTransportThread: Jan 17 14:59:41.197: [PA] the value to be parsed subscriber:command=reauthenticate+ and the length =35
*radiusCoASupportTransportThread: Jan 17 14:59:41.197: [PA] Reauthenticate command = reauthenticate+
*radiusCoASupportTransportThread: Jan 17 14:59:41.197: [PA] the value to be parsed subscriber:reauthenticate-type=last1 and the length =37
*radiusCoASupportTransportThread: Jan 17 14:59:41.197: [PA] the value to be parsed audit-session-id=28dde0220007d28a65a79d8e and the length =43
*radiusCoASupportTransportThread: Jan 17 14:59:41.197: [PA] audit session ID recieved in CoA = 28dde0220007d28a65a79d8e
*radiusCoASupportTransportThread: Jan 17 14:59:41.197: [PA] Message Authenticator calc'ed - c1:b2:d6:ce:6b:50:65:3e:e9:48:9a:d2:7f:79:bf:65 rawlen 202
*radiusCoASupportTransportThread: Jan 17 14:59:41.197: [PA] Request Authenticator - 36:94:64:0d:16:2f:7e:95:8e:3e:59:a8:c1:32:c9:25
*radiusCoASupportTransportThread: Jan 17 14:59:41.197: [PA] Received a 'CoA-Request' from 10.147.15.43 port 57932
*radiusCoASupportTransportThread: Jan 17 14:59:41.197: [PA] Packet contains 9 AVPs:
*radiusCoASupportTransportThread: Jan 17 14:59:41.197: [PA] AVP[01] Nas-Ip-Address...........................0x28dde022 (685629474) (4 bytes)
*radiusCoASupportTransportThread: Jan 17 14:59:41.198: [PA] AVP[03] Acct-Event-Time..........................0x65a79e05 (1705483781) (4 bytes)
*radiusCoASupportTransportThread: Jan 17 14:59:41.198: [PA] AVP[04] Message-Authenticator....................DATA (16 bytes)
*radiusCoASupportTransportThread: Jan 17 14:59:41.198: [PA] AVP[05] Unknown Attribute 0......................NULL (0 bytes)
*radiusCoASupportTransportThread: Jan 17 14:59:41.198: [PA] AVP[06] Unknown Attribute 0......................NULL (0 bytes)
*radiusCoASupportTransportThread: Jan 17 14:59:41.198: [PA] AVP[07] Unknown Attribute 0......................NULL (0 bytes)
*radiusCoASupportTransportThread: Jan 17 14:59:41.198: [PA] AVP[08] Unknown Attribute 0......................NULL (0 bytes)
*radiusCoASupportTransportThread: Jan 17 14:59:41.198: [PA] AVP[09] Unknown Attribute 0......................NULL (0 bytes)
*radiusCoASupportTransportThread: Jan 17 14:59:41.198: [PA] Handling a valid 'CoA-Request' regarding station 00:a5:54:53:7f:55
*radiusCoASupportTransportThread: Jan 17 14:59:41.198: [PA] CoA - Received IP Address : 40.221.224.34, Vlan ID: (received 228)
*radiusCoASupportTransportThread: Jan 17 14:59:41.198: [PA] Sent a 'CoA-Ack' to 10.147.15.43 (port:57932)
*apfOpenDtlSocket: Jan 17 14:59:42.882: [PA] c6:c7:a6:b5:2e:df Received management frame ASSOCIATION REQUEST on BSSID bc:26:c7:f1:14:86 destination addr bc:26:c7:f1:14:86 slotid 1
*apfMsConnTask_0: Jan 17 14:59:42.882: [PA] c6:c7:a6:b5:2e:df Updating the client capabiility as 5
*apfMsConnTask_0: Jan 17 14:59:42.882: [PA] c6:c7:a6:b5:2e:df Processing assoc-req station:c6:c7:a6:b5:2e:df AP:bc:26:c7:f1:14:80-01 ssid : testnew thread:257bb358
*apfMsConnTask_0: Jan 17 14:59:42.882: [PA] c6:c7:a6:b5:2e:df apfCreateMobileStationEntryWrapper (apf_ms.c:4510) Changing state for mobile c6:c7:a6:b5:2e:df on AP bc:26:c7:f1:14:80 from Idle to Idle
*apfMsConnTask_0: Jan 17 14:59:42.882: [PA] c6:c7:a6:b5:2e:df Adding mobile on LWAPP AP bc:26:c7:f1:14:80(1)
*apfMsConnTask_0: Jan 17 14:59:42.882: [PA] c6:c7:a6:b5:2e:df Created Acct-Session-ID (65a79e06/c6:c7:a6:b5:2e:df/523050) for the mobile
*apfMsConnTask_0: Jan 17 14:59:42.882: [PA] c6:c7:a6:b5:2e:df Setting hasApChnaged Flag as true. It is a fresh assoc request.
*apfMsConnTask_0: Jan 17 14:59:42.883: [PA] c6:c7:a6:b5:2e:df req rcv on open Wlan
*apfMsConnTask_0: Jan 17 14:59:42.883: [PA] c6:c7:a6:b5:2e:df Setting RTTS enabled to 0
*apfMsConnTask_0: Jan 17 14:59:42.883: [PA] c6:c7:a6:b5:2e:df Association received from mobile on BSSID bc:26:c7:f1:14:86 AP bgxly-7ar-lap-4
*apfMsConnTask_0: Jan 17 14:59:42.883: [PA] c6:c7:a6:b5:2e:df Station: c6:c7:a6:b5:2e:df 11v BSS Transition not enabled on the AP BC:26:C7:F1:14:80
*apfMsConnTask_0: Jan 17 14:59:42.883: [PA] c6:c7:a6:b5:2e:df Global 200 Clients are allowed to AP radio
*apfMsConnTask_0: Jan 17 14:59:42.883: [PA] c6:c7:a6:b5:2e:df Max Client Trap Threshold: 0 cur: 51
*apfMsConnTask_0: Jan 17 14:59:42.883: [PA] c6:c7:a6:b5:2e:df Rf profile 600 Clients are allowed to AP wlan
*apfMsConnTask_0: Jan 17 14:59:42.883: [PA] c6:c7:a6:b5:2e:df Updated local bridging VLAN to 228 while applying WLAN policy
*apfMsConnTask_0: Jan 17 14:59:42.883: [PA] c6:c7:a6:b5:2e:df Updated session timeout to 0 and Sleep timeout to 720 while applying WLAN policy
*apfMsConnTask_0: Jan 17 14:59:42.883: [PA] c6:c7:a6:b5:2e:df override for default ap group, marking intgrp NULL
*apfMsConnTask_0: Jan 17 14:59:42.883: [PA] c6:c7:a6:b5:2e:df Applying Interface(management) policy on Mobile, role Unassociated. Ms NAC State 0 Quarantine Vlan 0 Access Vlan 0
*apfMsConnTask_0: Jan 17 14:59:42.883: [PA] c6:c7:a6:b5:2e:df Re-applying interface (management) policy for client
*apfMsConnTask_0: Jan 17 14:59:42.883: [PA] c6:c7:a6:b5:2e:df After applying Interface(management) policy on Mobile, role Unassociated. Ms NAC State 2 Quarantine Vlan 0 Access Vlan 228
*apfMsConnTask_0: Jan 17 14:59:42.883: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 START (0) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:3498)
*apfMsConnTask_0: Jan 17 14:59:42.883: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 START (0) Changing Url ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255),Default action is '0' --- (caller apf_policy.c:3518)
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 START (0) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:3539)
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df Values before applying NASID - interfacetype:0, ovrd:0, mscb nasid:, interface nasid:, APgrpset:0
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df apfApplyWlanPolicy: Apply WLAN Policy over PMIPv6 Client Mobility Type, Tunnel User - 0
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df Check before Setting the NAS Id to WLAN specific Id ''
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df apf_policy.c:2783 Assigning the SGT 0 to mobile (earlier sgt 0)
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df Increment the SGT 0 policy count reference by the clients 1976
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df Check the client SGT 0 policy and push it to AP bc:26:c7:f1:14:80
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df In processSsidIE:7634 setting Central switched to TRUE
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df In processSsidIE:7637 apVapId = 10 and Split Acl Id = 65535
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df Applying site-specific Local Bridging override for station c6:c7:a6:b5:2e:df - vapId 10, site 'default-group', interface 'management'
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df Applying Local Bridging Interface Policy for station c6:c7:a6:b5:2e:df - vlan 228, interface id 0, interface 'management', nasId:''
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df processSsidIE statusCode is 0 and status is 0
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df processSsidIE ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df STA - rates (4): 48 72 224 108 0 0 0 0 0 0 0 0 0 0 0 0
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df suppRates statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df Assigning flex webauth IPv4-ACL ID :65535, IPv6-ACL ID:65535 for AP WLAN ID : 10
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df Allocate AID 177 slot 1 on AP bgxly-7ar-lap-4 #clients on this slot 52
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df Assoc Req BSSID bc:26:c7:f1:14:86 AP(bgxly-7ar-lap-4) slot 1 ssid (testnew) Tmstmp 3465551 AID 177 stCode 0/0 apChngd 0 oldAp 00:00:00:00:00:00
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 START (0) Initializing policy
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 START (0) Change state to AUTHCHECK (2) last state START (0)
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df apfVapSecurity=0x2040 L2=0 SkipWeb=0
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df AuthenticationRequired = 0
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 AUTHCHECK (2) Change state to L2AUTHCOMPLETE (4) last state AUTHCHECK (2)
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df Not Using WMM Compliance code qosCap 00
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df flex webauth ipv4 & ipv6 acl ids to be sent when fabric is disabled:65535/65535
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df flex webauth acl id to be sent :65535 name : client acl id :65535 name :
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df flex webauth ipv6 acl id to be sent :65535 name : client acl id :65535 name :
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df Vlan while overriding the policy = -1
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df sending to spamAddMobile vlanId -1 aclName = , flexAclId 65535
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP bc:26:c7:f1:14:80 vapId 10 apVapId 10 flex acl-name: v6acl-name
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 L2AUTHCOMPLETE (4) Change state to DHCP_REQD (7) last state L2AUTHCOMPLETE (4)
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df Not sending Registration for Fabric client. Primary and Secondary MS IP is zero
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df apfMsAssoStateInc
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df apfPemAddUser2 (apf_policy.c:465) Changing state for mobile c6:c7:a6:b5:2e:df on AP bc:26:c7:f1:14:80 from Idle to Associated
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df apfPemAddUser2:session timeout forstation c6:c7:a6:b5:2e:df - Session Tout 0, apfMsTimeOut '0' and sessionTimerRunning flag is 0
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df Stopping deletion of Mobile Station: (callerId: 48)
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df Func: apfPemAddUser2, Ms Timeout = 0, Session Timeout = 0
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df Sending assoc-resp with status 0 station:c6:c7:a6:b5:2e:df AP:bc:26:c7:f1:14:80-01 on apVapId 10
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df VHT Operation IE: width 40/0 ch 36 freq0 0 freq1 0 msc0 0xff msc1 0xff
*apfMsConnTask_0: Jan 17 14:59:42.884: [PA] c6:c7:a6:b5:2e:df Sending Assoc Response (status: '0') to station on AP bgxly-7ar-lap-4 on BSSID bc:26:c7:f1:14:86 ApVapId 10 Slot 1, mobility role 0
*apfMsConnTask_0: Jan 17 14:59:42.885: [PA] c6:c7:a6:b5:2e:df apfProcessAssocReq (apf_80211.c:12998) Changing state for mobile c6:c7:a6:b5:2e:df on AP bc:26:c7:f1:14:80 from Associated to Associated
*apfMsConnTask_0: Jan 17 14:59:42.885: [PA] c6:c7:a6:b5:2e:df Mobility query, PEM State: DHCP_REQD
*apfMsConnTask_0: Jan 17 14:59:42.885: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 DHCP_REQD (7) NO release MSCB
*apfMsConnTask_0: Jan 17 14:59:42.885: [PA] c6:c7:a6:b5:2e:df Building Mobile Announce :
*apfMsConnTask_0: Jan 17 14:59:42.885: [PA] c6:c7:a6:b5:2e:df Building Client Payload:
*apfMsConnTask_0: Jan 17 14:59:42.885: [PA] c6:c7:a6:b5:2e:df Client Ip: 0.0.0.0
*apfMsConnTask_0: Jan 17 14:59:42.885: [PA] c6:c7:a6:b5:2e:df Client Vlan Ip: 40.221.224.34, Vlan mask : 255.255.224.0
*apfMsConnTask_0: Jan 17 14:59:42.885: [PA] c6:c7:a6:b5:2e:df Client Vap Security: 8256
*apfMsConnTask_0: Jan 17 14:59:42.885: [PA] c6:c7:a6:b5:2e:df Virtual Ip: 10.0.0.1
*apfMsConnTask_0: Jan 17 14:59:42.885: [PA] c6:c7:a6:b5:2e:df ssid: testnew
*apfMsConnTask_0: Jan 17 14:59:42.885: [PA] c6:c7:a6:b5:2e:df Profile Name: testnew
*apfMsConnTask_0: Jan 17 14:59:42.885: [PA] c6:c7:a6:b5:2e:df Building VlanIpPayload.
*apfMsConnTask_0: Jan 17 14:59:42.885: [PA] c6:c7:a6:b5:2e:df Mobile Announce sent to 1 members of the local group.
*spamApTask7: Jan 17 14:59:42.886: [PA] c6:c7:a6:b5:2e:df Add SGT:0 to AP bc:26:c7:f1:14:80
*spamApTask7: Jan 17 14:59:42.886: [PA] c6:c7:a6:b5:2e:df Add CTS mobile SGT - Encoded the capwap payload for the mobile with SGT 0
*spamApTask7: Jan 17 14:59:42.886: [PA] c6:c7:a6:b5:2e:df MS IP NULL during AddMobile, not sending IP Distribution
*spamApTask7: Jan 17 14:59:42.886: [PA] c6:c7:a6:b5:2e:df Flex Ipv6 pre-auth acl is not present, not Encoding Flex Ipv6 acl for add mobile Payload
*spamApTask7: Jan 17 14:59:42.886: [PA] c6:c7:a6:b5:2e:df Flex Ipv6 post auth acl is not present, not updating add mobile Payload
*spamApTask7: Jan 17 14:59:42.886: [PA] c6:c7:a6:b5:2e:df Successful transmission of LWAPP Add-Mobile to AP bc:26:c7:f1:14:80 slotId 1 idx@22
*spamApTask7: Jan 17 14:59:42.886: [PA] c6:c7:a6:b5:2e:df Setting ADD_MOBILE (idx 23, action 0, last count 0) ack state for STA on AP bc:26:c7:f1:14:80
*apfOpenDtlSocket: Jan 17 14:59:42.911: [PA] c6:c7:a6:b5:2e:df Received management frame ACTION on BSSID bc:26:c7:f1:14:86 destination addr bc:26:c7:f1:14:86 slotid 1
*apfMsConnTask_0: Jan 17 14:59:42.911: [PA] c6:c7:a6:b5:2e:df Got action frame from the client (ActionCategory:5), payloadLen:12
*apfMsConnTask_0: Jan 17 14:59:42.911: [PA] c6:c7:a6:b5:2e:df Station: c6:c7:a6:b5:2e:df sent 802.11K neighbor request to AP BC:26:C7:F1:14:80
*apfMsConnTask_0: Jan 17 14:59:42.911: [PA] c6:c7:a6:b5:2e:df Station: c6:c7:a6:b5:2e:df requested neighbors on non XOR roam capable AP BC:26:C7:F1:14:80 Slot 1
*DHCP Socket Task: Jan 17 14:59:43.072: [PA] c6:c7:a6:b5:2e:df DHCP received op BOOTREQUEST (1) (len 314,vlan 228, port 8, encap 0xec03, xid 0x667c0103)
*DHCP Socket Task: Jan 17 14:59:43.072: [PA] c6:c7:a6:b5:2e:df DHCP (encap type 0xec03) mstype 0ff:ff:ff:ff:ff:ff
*DHCP Socket Task: Jan 17 14:59:43.072: [PA] c6:c7:a6:b5:2e:df DHCP dropping packet due to ongoing mobility handshake exchange, (siaddr 0.0.0.0, mobility state = 'apfMsMmQueryRequested'
*DHCP Socket Task: Jan 17 14:59:43.571: [PA] c6:c7:a6:b5:2e:df DHCP received op BOOTREQUEST (1) (len 314,vlan 228, port 8, encap 0xec03, xid 0x667c0103)
*DHCP Socket Task: Jan 17 14:59:43.571: [PA] c6:c7:a6:b5:2e:df DHCP (encap type 0xec03) mstype 0ff:ff:ff:ff:ff:ff
*DHCP Socket Task: Jan 17 14:59:43.571: [PA] c6:c7:a6:b5:2e:df DHCP dropping packet due to ongoing mobility handshake exchange, (siaddr 0.0.0.0, mobility state = 'apfMsMmQueryRequested'
*DHCP Socket Task: Jan 17 14:59:44.099: [PA] c6:c7:a6:b5:2e:df DHCP received op BOOTREQUEST (1) (len 314,vlan 228, port 8, encap 0xec03, xid 0x667c0103)
*DHCP Socket Task: Jan 17 14:59:44.099: [PA] c6:c7:a6:b5:2e:df DHCP (encap type 0xec03) mstype 0ff:ff:ff:ff:ff:ff
*DHCP Socket Task: Jan 17 14:59:44.099: [PA] c6:c7:a6:b5:2e:df DHCP dropping packet due to ongoing mobility handshake exchange, (siaddr 0.0.0.0, mobility state = 'apfMsMmQueryRequested'
*DHCP Socket Task: Jan 17 14:59:44.598: [PA] c6:c7:a6:b5:2e:df DHCP received op BOOTREQUEST (1) (len 314,vlan 228, port 8, encap 0xec03, xid 0x667c0103)
*DHCP Socket Task: Jan 17 14:59:44.599: [PA] c6:c7:a6:b5:2e:df DHCP (encap type 0xec03) mstype 0ff:ff:ff:ff:ff:ff
*DHCP Socket Task: Jan 17 14:59:44.599: [PA] c6:c7:a6:b5:2e:df DHCP dropping packet due to ongoing mobility handshake exchange, (siaddr 0.0.0.0, mobility state = 'apfMsMmQueryRequested'
*DHCP Socket Task: Jan 17 14:59:45.598: [PA] c6:c7:a6:b5:2e:df DHCP received op BOOTREQUEST (1) (len 314,vlan 228, port 8, encap 0xec03, xid 0x667c0103)
*DHCP Socket Task: Jan 17 14:59:45.598: [PA] c6:c7:a6:b5:2e:df DHCP (encap type 0xec03) mstype 0ff:ff:ff:ff:ff:ff
*DHCP Socket Task: Jan 17 14:59:45.598: [PA] c6:c7:a6:b5:2e:df DHCP dropping packet due to ongoing mobility handshake exchange, (siaddr 0.0.0.0, mobility state = 'apfMsMmQueryRequested'
*apfReceiveTask: Jan 17 14:59:45.788: [PA] c6:c7:a6:b5:2e:df Attempting anchor export for mobile c6:c7:a6:b5:2e:df
*apfReceiveTask: Jan 17 14:59:45.788: [PA] c6:c7:a6:b5:2e:df Building Client Payload:
*apfReceiveTask: Jan 17 14:59:45.788: [PA] c6:c7:a6:b5:2e:df Client Ip: 0.0.0.0
*apfReceiveTask: Jan 17 14:59:45.788: [PA] c6:c7:a6:b5:2e:df Client Vlan Ip: 40.221.224.34, Vlan mask : 255.255.224.0
*apfReceiveTask: Jan 17 14:59:45.788: [PA] c6:c7:a6:b5:2e:df Client Vap Security: 8256
*apfReceiveTask: Jan 17 14:59:45.788: [PA] c6:c7:a6:b5:2e:df Virtual Ip: 10.0.0.1
*apfReceiveTask: Jan 17 14:59:45.788: [PA] c6:c7:a6:b5:2e:df ssid: testnew
*apfReceiveTask: Jan 17 14:59:45.788: [PA] c6:c7:a6:b5:2e:df Building Client profile name Payload:
*apfReceiveTask: Jan 17 14:59:45.788: [PA] c6:c7:a6:b5:2e:df Profile Name: testnew
*apfReceiveTask: Jan 17 14:59:45.788: [PA] c6:c7:a6:b5:2e:df Building policy payload
*apfReceiveTask: Jan 17 14:59:45.788: [PA] c6:c7:a6:b5:2e:df mmAnchorExportSend: Building ExportForeignLradMac Payload Lrad Mac: bc:26:c7:f1:14:80
*apfReceiveTask: Jan 17 14:59:45.788: [PA] c6:c7:a6:b5:2e:df Created Cisco-Audit-Session-ID for the mobile: 28dde0220007d2ce65a79e09 type: local
*apfReceiveTask: Jan 17 14:59:45.788: [PA] c6:c7:a6:b5:2e:df Building Audit session ID (28dde0220007d2ce65a79e09) payload in Mobility handoff
*apfReceiveTask: Jan 17 14:59:45.788: [PA] c6:c7:a6:b5:2e:df Building IPv6 Client Payload:
*apfReceiveTask: Jan 17 14:59:45.788: [PA] c6:c7:a6:b5:2e:df mmBuildIPv6ClientPayload: IPv6: Built IPv6 client payload vlan =228, numIPv6Addr =0
*apfReceiveTask: Jan 17 14:59:45.788: [PA] c6:c7:a6:b5:2e:df SGT Payload buiding in handoff 0 (len 6)
*apfReceiveTask: Jan 17 14:59:45.788: [PA] c6:c7:a6:b5:2e:df Export Anchor request sent to 10.208.134.212
*DHCP Socket Task: Jan 17 14:59:45.991: [PA] c6:c7:a6:b5:2e:df DHCP received op BOOTREQUEST (1) (len 314,vlan 228, port 8, encap 0xec03, xid 0x667c0103)
*DHCP Socket Task: Jan 17 14:59:45.991: [PA] c6:c7:a6:b5:2e:df DHCP (encap type 0xec03) mstype 0ff:ff:ff:ff:ff:ff
*DHCP Socket Task: Jan 17 14:59:45.991: [PA] c6:c7:a6:b5:2e:df DHCP dropping packet due to ongoing mobility handshake exchange, (siaddr 0.0.0.0, mobility state = 'apfMsMmAnchorExportRequested'
*DHCP Socket Task: Jan 17 14:59:46.491: [PA] c6:c7:a6:b5:2e:df DHCP received op BOOTREQUEST (1) (len 314,vlan 228, port 8, encap 0xec03, xid 0x667c0103)
*DHCP Socket Task: Jan 17 14:59:46.491: [PA] c6:c7:a6:b5:2e:df DHCP (encap type 0xec03) mstype 0ff:ff:ff:ff:ff:ff
*DHCP Socket Task: Jan 17 14:59:46.491: [PA] c6:c7:a6:b5:2e:df DHCP dropping packet due to ongoing mobility handshake exchange, (siaddr 0.0.0.0, mobility state = 'apfMsMmAnchorExportRequested'
*DHCP Socket Task: Jan 17 14:59:46.492: [PA] c6:c7:a6:b5:2e:df DHCP received op BOOTREQUEST (1) (len 314,vlan 228, port 8, encap 0xec03, xid 0x667c0103)
*DHCP Socket Task: Jan 17 14:59:46.492: [PA] c6:c7:a6:b5:2e:df DHCP (encap type 0xec03) mstype 0ff:ff:ff:ff:ff:ff
*DHCP Socket Task: Jan 17 14:59:46.492: [PA] c6:c7:a6:b5:2e:df DHCP dropping packet due to ongoing mobility handshake exchange, (siaddr 0.0.0.0, mobility state = 'apfMsMmAnchorExportRequested'
*mmMobility: Jan 17 14:59:46.780: [PA] c6:c7:a6:b5:2e:df Mobility Anchor packet retry: Peer IP: 10.208.134.212, Anchor IP: 0.0.0.0
*DHCP Socket Task: Jan 17 14:59:47.492: [PA] c6:c7:a6:b5:2e:df DHCP received op BOOTREQUEST (1) (len 314,vlan 228, port 8, encap 0xec03, xid 0x667c0103)
*DHCP Socket Task: Jan 17 14:59:47.492: [PA] c6:c7:a6:b5:2e:df DHCP (encap type 0xec03) mstype 0ff:ff:ff:ff:ff:ff
*DHCP Socket Task: Jan 17 14:59:47.492: [PA] c6:c7:a6:b5:2e:df DHCP dropping packet due to ongoing mobility handshake exchange, (siaddr 0.0.0.0, mobility state = 'apfMsMmAnchorExportRequested'
*mmMobility: Jan 17 14:59:47.771: [PA] c6:c7:a6:b5:2e:df Mobility Anchor packet retry: Peer IP: 10.208.134.212, Anchor IP: 0.0.0.0
*apfReceiveTask: Jan 17 14:59:48.763: [PA] c6:c7:a6:b5:2e:df apfMmProcessResponse: Got Anchor Close from mmMipAnchorResendTimeoutHandler for mobile c6:c7:a6:b5:2e:df, delete mobile. reason code = 2 MmRole : 0
*apfReceiveTask: Jan 17 14:59:48.763: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 DHCP_REQD (7) mobility role update request from Unassociated to Handoff
Peer = 10.208.134.212, Old Anchor = 10.208.134.212, New Anchor = 0.0.0.0
*apfReceiveTask: Jan 17 14:59:48.763: [PA] c6:c7:a6:b5:2e:df IP Addr Clear. AP MAC[bc:26:c7:f1:14:80] Role[Unassociated] Pem State [DHCP_REQD] Connected Time[6]
*apfReceiveTask: Jan 17 14:59:48.763: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 DHCP_REQD (7) Reached ERROR: from line 7760
*apfReceiveTask: Jan 17 14:59:48.764: [PA] c6:c7:a6:b5:2e:df apfMmProcessCloseResponse (apf_mm.c:723) Expiring Mobile!
*apfReceiveTask: Jan 17 14:59:48.764: [PA] c6:c7:a6:b5:2e:df apfMsExpireMobileStation (apf_ms.c:8142) Changing state for mobile c6:c7:a6:b5:2e:df on AP bc:26:c7:f1:14:80 from Associated to Disassociated
*apfReceiveTask: Jan 17 14:59:48.764: [PA] c6:c7:a6:b5:2e:df apfMsExpireMobileStation (apf_ms.c:8294) Changing state for mobile c6:c7:a6:b5:2e:df on AP bc:26:c7:f1:14:80 from Disassociated to Idle
*apfReceiveTask: Jan 17 14:59:48.764: [PA] c6:c7:a6:b5:2e:df pemApfDeleteMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfReceiveTask: Jan 17 14:59:48.764: [PA] c6:c7:a6:b5:2e:df the value of url acl preserve flag is 0 for mobile c6:c7:a6:b5:2e:df (caller pem_api.c:5292)
*apfReceiveTask: Jan 17 14:59:48.764: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 DHCP_REQD (7) Deleted mobile LWAPP rule on AP [bc:26:c7:f1:14:80]
*apfReceiveTask: Jan 17 14:59:48.764: [PA] c6:c7:a6:b5:2e:df Succesfully freed AID 177, slot 1 on AP bc:26:c7:f1:14:80, #client on this slot 50
*spamApTask7: Jan 17 14:59:48.764: [PA] c6:c7:a6:b5:2e:df Setting DEL_MOBILE (seqno 0, action 6) ack state for STA on AP bc:26:c7:f1:14:80
*spamApTask7: Jan 17 14:59:48.764: [PA] c6:c7:a6:b5:2e:df Setting ADD_MOBILE (idx 26, seqno 115, action 6, count 115, last count 115) ack state for STA on AP bc:26:c7:f1:14:80
*spamApTask7: Jan 17 14:59:48.764: [PA] c6:c7:a6:b5:2e:df Delete Mobile request with reason 'MN_DEL_PEM_CLEANUP' on slot 1 sent to the AP bc:26:c7:f1:14:80 IP: 40.221.225.47:5256.
*apfReceiveTask: Jan 17 14:59:48.764: [PA] c6:c7:a6:b5:2e:df Deleting mobile on AP bc:26:c7:f1:14:80(1)
*apfReceiveTask: Jan 17 14:59:48.764: [PA] c6:c7:a6:b5:2e:df apf_ms.c:5636 Clearing the SGT 0 of mobile
*apfReceiveTask: Jan 17 14:59:48.764: [PA] c6:c7:a6:b5:2e:df Decrement the SGT 0 policy count reference by the clients 1976
*spamApTask7: Jan 17 14:59:48.767: [PA] c6:c7:a6:b5:2e:df Received add/del ack packet with sequence number: got 115 expected 115 action = 6
*spamApTask7: Jan 17 14:59:48.767: [PA] c6:c7:a6:b5:2e:df Received DELETE mobile, reasonCode UNKNOWN, deleteReason 15 from AP bc:26:c7:f1:14:80, slot 1 ...cleaning up mscb
*apfOpenDtlSocket: Jan 17 14:59:50.635: [PA] c6:c7:a6:b5:2e:df Received management frame REASSOCIATION REQUEST on BSSID bc:26:c7:f1:14:89 destination addr bc:26:c7:f1:14:89 slotid 0
*apfMsConnTask_0: Jan 17 14:59:50.635: [PA] c6:c7:a6:b5:2e:df Updating the client capabiility as 5
*apfMsConnTask_0: Jan 17 14:59:50.635: [PA] c6:c7:a6:b5:2e:df Processing assoc-req station:c6:c7:a6:b5:2e:df AP:bc:26:c7:f1:14:80-00 ssid : testnew thread:257bb358
*apfMsConnTask_0: Jan 17 14:59:50.635: [PA] c6:c7:a6:b5:2e:df apfCreateMobileStationEntryWrapper (apf_ms.c:4510) Changing state for mobile c6:c7:a6:b5:2e:df on AP bc:26:c7:f1:14:80 from Idle to Idle
*apfMsConnTask_0: Jan 17 14:59:50.635: [PA] c6:c7:a6:b5:2e:df Adding mobile on LWAPP AP bc:26:c7:f1:14:80(0)
*apfMsConnTask_0: Jan 17 14:59:50.636: [PA] c6:c7:a6:b5:2e:df Created Acct-Session-ID (65a79e0e/c6:c7:a6:b5:2e:df/523056) for the mobile
*apfMsConnTask_0: Jan 17 14:59:50.636: [PA] c6:c7:a6:b5:2e:df Setting hasApChnaged Flag as true. It is a fresh assoc request.
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df req rcv on open Wlan
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df Setting RTTS enabled to 0
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df Reassociation received from mobile on BSSID bc:26:c7:f1:14:89 AP bgxly-7ar-lap-4
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df Station: c6:c7:a6:b5:2e:df 11v BSS Transition not enabled on the AP BC:26:C7:F1:14:80
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df Global 200 Clients are allowed to AP radio
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df Max Client Trap Threshold: 0 cur: 4
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df Rf profile 600 Clients are allowed to AP wlan
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df Updated local bridging VLAN to 228 while applying WLAN policy
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df Updated session timeout to 0 and Sleep timeout to 720 while applying WLAN policy
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df override for default ap group, marking intgrp NULL
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df Applying Interface(management) policy on Mobile, role Unassociated. Ms NAC State 0 Quarantine Vlan 0 Access Vlan 0
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df Re-applying interface (management) policy for client
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df After applying Interface(management) policy on Mobile, role Unassociated. Ms NAC State 2 Quarantine Vlan 0 Access Vlan 228
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 START (0) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:3498)
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 START (0) Changing Url ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255),Default action is '0' --- (caller apf_policy.c:3518)
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 START (0) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:3539)
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df Values before applying NASID - interfacetype:0, ovrd:0, mscb nasid:, interface nasid:, APgrpset:0
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df apfApplyWlanPolicy: Apply WLAN Policy over PMIPv6 Client Mobility Type, Tunnel User - 0
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df Check before Setting the NAS Id to WLAN specific Id ''
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df apf_policy.c:2783 Assigning the SGT 0 to mobile (earlier sgt 0)
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df Increment the SGT 0 policy count reference by the clients 1976
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df Check the client SGT 0 policy and push it to AP bc:26:c7:f1:14:80
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df In processSsidIE:7634 setting Central switched to TRUE
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df In processSsidIE:7637 apVapId = 10 and Split Acl Id = 65535
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df Applying site-specific Local Bridging override for station c6:c7:a6:b5:2e:df - vapId 10, site 'default-group', interface 'management'
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df Applying Local Bridging Interface Policy for station c6:c7:a6:b5:2e:df - vlan 228, interface id 0, interface 'management', nasId:''
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df processSsidIE statusCode is 0 and status is 0
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df processSsidIE ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df STA - rates (4): 176 72 96 108 0 0 0 0 0 0 0 0 0 0 0 0
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df suppRates statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df Assigning flex webauth IPv4-ACL ID :65535, IPv6-ACL ID:65535 for AP WLAN ID : 10
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df Allocate AID 21 slot 0 on AP bgxly-7ar-lap-4 #clients on this slot 5
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df Reassoc Req BSSID bc:26:c7:f1:14:89 AP(bgxly-7ar-lap-4) slot 0 ssid (testnew) Tmstmp 3465558 AID 21 stCode 0/0 apChngd 0 oldAp 00:00:00:00:00:00
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 START (0) Initializing policy
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 START (0) Change state to AUTHCHECK (2) last state START (0)
*apfMsConnTask_0: Jan 17 14:59:50.637: [PA] c6:c7:a6:b5:2e:df apfVapSecurity=0x2040 L2=0 SkipWeb=0
*apfMsConnTask_0: Jan 17 14:59:50.638: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 AUTHCHECK (2) Change state to L2AUTHCOMPLETE (4) last state AUTHCHECK (2)
*apfMsConnTask_0: Jan 17 14:59:50.638: [PA] c6:c7:a6:b5:2e:df Not Using WMM Compliance code qosCap 00
*apfMsConnTask_0: Jan 17 14:59:50.638: [PA] c6:c7:a6:b5:2e:df flex webauth ipv4 & ipv6 acl ids to be sent when fabric is disabled:65535/65535
*apfMsConnTask_0: Jan 17 14:59:50.638: [PA] c6:c7:a6:b5:2e:df flex webauth ipv6 acl id to be sent :65535 name : client acl id :65535 name :
*apfMsConnTask_0: Jan 17 14:59:50.638: [PA] c6:c7:a6:b5:2e:df Vlan while overriding the policy = -1
*apfMsConnTask_0: Jan 17 14:59:50.638: [PA] c6:c7:a6:b5:2e:df sending to spamAddMobile vlanId -1 aclName = , flexAclId 65535
*apfMsConnTask_0: Jan 17 14:59:50.638: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP bc:26:c7:f1:14:80 vapId 10 apVapId 10 flex acl-name: v6acl-name
*apfMsConnTask_0: Jan 17 14:59:50.638: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 L2AUTHCOMPLETE (4) Change state to DHCP_REQD (7) last state L2AUTHCOMPLETE (4)
*apfMsConnTask_0: Jan 17 14:59:50.638: [PA] c6:c7:a6:b5:2e:df Not sending Registration for Fabric client. Primary and Secondary MS IP is zero
*apfMsConnTask_0: Jan 17 14:59:50.638: [PA] c6:c7:a6:b5:2e:df apfMsAssoStateInc
*apfMsConnTask_0: Jan 17 14:59:50.638: [PA] c6:c7:a6:b5:2e:df apfPemAddUser2 (apf_policy.c:465) Changing state for mobile c6:c7:a6:b5:2e:df on AP bc:26:c7:f1:14:80 from Idle to Associated
*apfMsConnTask_0: Jan 17 14:59:50.638: [PA] c6:c7:a6:b5:2e:df apfPemAddUser2:session timeout forstation c6:c7:a6:b5:2e:df - Session Tout 0, apfMsTimeOut '0' and sessionTimerRunning flag is 0
*apfMsConnTask_0: Jan 17 14:59:50.638: [PA] c6:c7:a6:b5:2e:df Stopping deletion of Mobile Station: (callerId: 48)
*apfMsConnTask_0: Jan 17 14:59:50.638: [PA] c6:c7:a6:b5:2e:df Func: apfPemAddUser2, Ms Timeout = 0, Session Timeout = 0
*apfMsConnTask_0: Jan 17 14:59:50.638: [PA] c6:c7:a6:b5:2e:df Sending assoc-resp with status 0 station:c6:c7:a6:b5:2e:df AP:bc:26:c7:f1:14:80-00 on apVapId 10
*apfMsConnTask_0: Jan 17 14:59:50.638: [PA] c6:c7:a6:b5:2e:df Sending Assoc Response (status: '0') to station on AP bgxly-7ar-lap-4 on BSSID bc:26:c7:f1:14:89 ApVapId 10 Slot 0, mobility role 0
*apfMsConnTask_0: Jan 17 14:59:50.638: [PA] c6:c7:a6:b5:2e:df apfProcessAssocReq (apf_80211.c:12998) Changing state for mobile c6:c7:a6:b5:2e:df on AP bc:26:c7:f1:14:80 from Associated to Associated
*apfMsConnTask_0: Jan 17 14:59:50.638: [PA] c6:c7:a6:b5:2e:df Mobility query, PEM State: DHCP_REQD
*apfMsConnTask_0: Jan 17 14:59:50.638: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 DHCP_REQD (7) NO release MSCB
*apfMsConnTask_0: Jan 17 14:59:50.638: [PA] c6:c7:a6:b5:2e:df Building Mobile Announce :
*apfMsConnTask_0: Jan 17 14:59:50.638: [PA] c6:c7:a6:b5:2e:df Building Client Payload:
*apfMsConnTask_0: Jan 17 14:59:50.638: [PA] c6:c7:a6:b5:2e*apfReceiveTask: Jan 17 14:59:53.524: [PA] c6:c7:a6:b5:2e:df Attempting anchor export for mobile c6:c7:a6:b5:2e:df
*apfReceiveTask: Jan 17 14:59:53.524: [PA] c6:c7:a6:b5:2e:df Building Client Payload:
*apfReceiveTask: Jan 17 14:59:53.524: [PA] c6:c7:a6:b5:2e:df Client Ip: 0.0.0.0
*apfReceiveTask: Jan 17 14:59:53.524: [PA] c6:c7:a6:b5:2e:df Client Vap Security: 8256
*apfReceiveTask: Jan 17 14:59:53.524: [PA] c6:c7:a6:b5:2e:df Virtual Ip: 10.0.0.1
*apfReceiveTask: Jan 17 14:59:53.524: [PA] c6:c7:a6:b5:2e:df ssid: testnew
*apfReceiveTask: Jan 17 14:59:53.524: [PA] c6:c7:a6:b5:2e:df Building Client profile name Payload:
*apfReceiveTask: Jan 17 14:59:53.524: [PA] c6:c7:a6:b5:2e:df Profile Name: testnew
*apfReceiveTask: Jan 17 14:59:53.524: [PA] c6:c7:a6:b5:2e:df Building policy payload
*apfReceiveTask: Jan 17 14:59:53.524: [PA] c6:c7:a6:b5:2e:df mmAnchorExportSend: Building ExportForeignLradMac Payload Lrad Mac: bc:26:c7:f1:14:80
*apfReceiveTask: Jan 17 14:59:53.524: [PA] c6:c7:a6:b5:2e:df Created Cisco-Audit-Session-ID for the mobile: 28dde0220007d2d465a79e11 type: local
*apfReceiveTask: Jan 17 14:59:53.524: [PA] c6:c7:a6:b5:2e:df Building Audit session ID (28dde0220007d2d465a79e11) payload in Mobility handoff
*apfReceiveTask: Jan 17 14:59:53.524: [PA] c6:c7:a6:b5:2e:df Building IPv6 Client Payload:
*apfReceiveTask: Jan 17 14:59:53.524: [PA] c6:c7:a6:b5:2e:df mmBuildIPv6ClientPayload: IPv6: Built IPv6 client payload vlan =228, numIPv6Addr =0
*apfReceiveTask: Jan 17 14:59:53.524: [PA] c6:c7:a6:b5:2e:df SGT Payload buiding in handoff 0 (len 6)
*apfReceiveTask: Jan 17 14:59:53.524: [PA] c6:c7:a6:b5:2e:df SGT Payload built in Export Anchor Req 0
*apfReceiveTask: Jan 17 14:59:53.524: [PA] c6:c7:a6:b5:2e:df Export Anchor request sent to 10.208.134.212
*mmMobility: Jan 17 14:59:54.516: [PA] c6:c7:a6:b5:2e:df Mobility Anchor packet retry: Peer IP: 10.208.134.212, Anchor IP: 0.0.0.0
*mmMobility: Jan 17 14:59:55.508: [PA] c6:c7:a6:b5:2e:df Mobility Anchor packet retry: Peer IP: 10.208.134.212, Anchor IP: 0.0.0.0
*apfReceiveTask: Jan 17 14:59:56.499: [PA] c6:c7:a6:b5:2e:df apfMmProcessResponse: Got Anchor Close from mmMipAnchorResendTimeoutHandler for mobile c6:c7:a6:b5:2e:df, delete mobile. reason code = 2 MmRole : 0
*apfReceiveTask: Jan 17 14:59:56.499: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 DHCP_REQD (7) mobility role update request from Unassociated to Handoff
*apfReceiveTask: Jan 17 14:59:56.499: [PA] c6:c7:a6:b5:2e:df IP Addr Clear. AP MAC[bc:26:c7:f1:14:80] Role[Unassociated] Pem State [DHCP_REQD] Connected Time[6]
*apfReceiveTask: Jan 17 14:59:56.499: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 DHCP_REQD (7) Reached ERROR: from line 7760
*apfReceiveTask: Jan 17 14:59:56.499: [PA] c6:c7:a6:b5:2e:df apfMmProcessCloseResponse (apf_mm.c:723) Expiring Mobile!
*apfReceiveTask: Jan 17 14:59:56.499: [PA] c6:c7:a6:b5:2e:df apfMsExpireMobileStation (apf_ms.c:8142) Changing state for mobile c6:c7:a6:b5:2e:df on AP bc:26:c7:f1:14:80 from Associated to Disassociated
*apfReceiveTask: Jan 17 14:59:56.499: [PA] c6:c7:a6:b5:2e:df apfMsAssoStateDec
*apfReceiveTask: Jan 17 14:59:56.499: [PA] c6:c7:a6:b5:2e:df apfMsExpireMobileStation (apf_ms.c:8294) Changing state for mobile c6:c7:a6:b5:2e:df on AP bc:26:c7:f1:14:80 from Disassociated to Idle
*apfReceiveTask: Jan 17 14:59:56.500: [PA] c6:c7:a6:b5:2e:df pemApfDeleteMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfReceiveTask: Jan 17 14:59:56.500: [PA] c6:c7:a6:b5:2e:df the value of url acl preserve flag is 0 for mobile c6:c7:a6:b5:2e:df (caller pem_api.c:5292)
*apfReceiveTask: Jan 17 14:59:56.500: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 DHCP_REQD (7) Deleted mobile LWAPP rule on AP [bc:26:c7:f1:14:80]
*apfReceiveTask: Jan 17 14:59:56.500: [PA] c6:c7:a6:b5:2e:df Succesfully freed AID 21, slot 0 on AP bc:26:c7:f1:14:80, #client on this slot 3
*spamApTask7: Jan 17 14:59:56.500: [PA] c6:c7:a6:b5:2e:df Setting DEL_MOBILE (seqno 0, action 6) ack state for STA on AP bc:26:c7:f1:14:80
*spamApTask7: Jan 17 14:59:56.500: [PA] c6:c7:a6:b5:2e:df Setting ADD_MOBILE (idx 33, seqno 122, action 6, count 122, last count 122) ack state for STA on AP bc:26:c7:f1:14:80
*spamApTask7: Jan 17 14:59:56.500: [PA] c6:c7:a6:b5:2e:df Delete Mobile request with reason 'MN_DEL_PEM_CLEANUP' on slot 0 sent to the AP bc:26:c7:f1:14:80 IP: 40.221.225.47:5256.
*apfReceiveTask: Jan 17 14:59:56.500: [PA] c6:c7:a6:b5:2e:df Deleting mobile on AP bc:26:c7:f1:14:80(0)
*apfReceiveTask: Jan 17 14:59:56.500: [PA] c6:c7:a6:b5:2e:df apf_ms.c:5636 Clearing the SGT 0 of mobile
*apfReceiveTask: Jan 17 14:59:56.500: [PA] c6:c7:a6:b5:2e:df Decrement the SGT 0 policy count reference by the clients 1971
*spamApTask7: Jan 17 14:59:56.502: [PA] c6:c7:a6:b5:2e:df Received add/del ack packet with sequence number: got 122 expected 122 action = 6
*spamApTask7: Jan 17 14:59:56.502: [PA] c6:c7:a6:b5:2e:df Received DELETE mobile, reasonCode UNKNOWN, deleteReason 15 from AP bc:26:c7:f1:14:80, slot 0 ...cleaning up mscb
*apfOpenDtlSocket: Jan 17 14:59:57.982: [PA] c6:c7:a6:b5:2e:df Received management frame REASSOCIATION REQUEST on BSSID bc:26:c7:f1:14:86 destination addr bc:26:c7:f1:14:86 slotid 1
*apfMsConnTask_0: Jan 17 14:59:57.983: [PA] c6:c7:a6:b5:2e:df Updating the client capabiility as 5
*apfMsConnTask_0: Jan 17 14:59:57.983: [PA] c6:c7:a6:b5:2e:df Processing assoc-req station:c6:c7:a6:b5:2e:df AP:bc:26:c7:f1:14:80-01 ssid : testnew thread:257bb358
*apfMsConnTask_0: Jan 17 14:59:57.983: [PA] c6:c7:a6:b5:2e:df apfCreateMobileStationEntryWrapper (apf_ms.c:4510) Changing state for mobile c6:c7:a6:b5:2e:df on AP bc:26:c7:f1:14:80 from Idle to Idle
*apfMsConnTask_0: Jan 17 14:59:57.983: [PA] c6:c7:a6:b5:2e:df Adding mobile on LWAPP AP bc:26:c7:f1:14:80(1)
*apfMsConnTask_0: Jan 17 14:59:57.983: [PA] c6:c7:a6:b5:2e:df Created Acct-Session-ID (65a79e15/c6:c7:a6:b5:2e:df/523057) for the mobile
*apfMsConnTask_0: Jan 17 14:59:57.983: [PA] c6:c7:a6:b5:2e:df Setting hasApChnaged Flag as true. It is a fresh assoc request.
*apfMsConnTask_0: Jan 17 14:59:57.984: [PA] c6:c7:a6:b5:2e:df req rcv on open Wlan
*apfMsConnTask_0: Jan 17 14:59:57.984: [PA] c6:c7:a6:b5:2e:df Setting RTTS enabled to 0
*apfMsConnTask_0: Jan 17 14:59:57.984: [PA] c6:c7:a6:b5:2e:df Reassociation received from mobile on BSSID bc:26:c7:f1:14:86 AP bgxly-7ar-lap-4
*apfMsConnTask_0: Jan 17 14:59:57.984: [PA] c6:c7:a6:b5:2e:df Station: c6:c7:a6:b5:2e:df 11v BSS Transition not enabled on the AP BC:26:C7:F1:14:80
*apfMsConnTask_0: Jan 17 14:59:57.984: [PA] c6:c7:a6:b5:2e:df Global 200 Clients are allowed to AP radio
*apfMsConnTask_0: Jan 17 14:59:57.984: [PA] c6:c7:a6:b5:2e:df Max Client Trap Threshold: 0 cur: 50
*apfMsConnTask_0: Jan 17 14:59:57.984: [PA] c6:c7:a6:b5:2e:df Rf profile 600 Clients are allowed to AP wlan
*apfMsConnTask_0: Jan 17 14:59:57.984: [PA] c6:c7:a6:b5:2e:df Updated local bridging VLAN to 228 while applying WLAN policy
*apfMsConnTask_0: Jan 17 14:59:57.984: [PA] c6:c7:a6:b5:2e:df override for default ap group, marking intgrp NULL
*apfMsConnTask_0: Jan 17 14:59:57.984: [PA] c6:c7:a6:b5:2e:df Applying Interface(management) policy on Mobile, role Unassociated. Ms NAC State 0 Quarantine Vlan 0 Access Vlan 0
*apfMsConnTask_0: Jan 17 14:59:57.984: [PA] c6:c7:a6:b5:2e:df Re-applying interface (management) policy for client
*apfMsConnTask_0: Jan 17 14:59:57.984: [PA] c6:c7:a6:b5:2e:df After applying Interface(management) policy on Mobile, role Unassociated. Ms NAC State 2 Quarantine Vlan 0 Access Vlan 228
*apfMsConnTask_0: Jan 17 14:59:57.984: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 START (0) Changing Url ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255),Default action is '0' --- (caller apf_policy.c:3518)
*apfMsConnTask_0: Jan 17 14:59:57.984: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 START (0) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:3539)
*apfMsConnTask_0: Jan 17 14:59:57.984: [PA] c6:c7:a6:b5:2e:df Values before applying NASID - interfacetype:0, ovrd:0, mscb nasid:, interface nasid:, APgrpset:0
*apfMsConnTask_0: Jan 17 14:59:57.984: [PA] c6:c7:a6:b5:2e:df apfApplyWlanPolicy: Apply WLAN Policy over PMIPv6 Client Mobility Type, Tunnel User - 0
*apfMsConnTask_0: Jan 17 14:59:57.984: [PA] c6:c7:a6:b5:2e:df Check before Setting the NAS Id to WLAN specific Id ''
*apfMsConnTask_0: Jan 17 14:59:57.984: [PA] c6:c7:a6:b5:2e:df apf_policy.c:2783 Assigning the SGT 0 to mobile (earlier sgt 0)
*apfMsConnTask_0: Jan 17 14:59:57.984: [PA] c6:c7:a6:b5:2e:df Increment the SGT 0 policy count reference by the clients 1971
*apfMsConnTask_0: Jan 17 14:59:57.985: [PA] c6:c7:a6:b5:2e:df In processSsidIE:7634 setting Central switched to TRUE
*apfMsConnTask_0: Jan 17 14:59:57.985: [PA] c6:c7:a6:b5:2e:df In processSsidIE:7637 apVapId = 10 and Split Acl Id = 65535
*apfMsConnTask_0: Jan 17 14:59:57.985: [PA] c6:c7:a6:b5:2e:df Applying site-specific Local Bridging override for station c6:c7:a6:b5:2e:df - vapId 10, site 'default-group', interface 'management'
*apfMsConnTask_0: Jan 17 14:59:57.985: [PA] c6:c7:a6:b5:2e:df Applying Local Bridging Interface Policy for station c6:c7:a6:b5:2e:df - vlan 228, interface id 0, interface 'management', nasId:''
*apfMsConnTask_0: Jan 17 14:59:57.985: [PA] c6:c7:a6:b5:2e:df processSsidIE statusCode is 0 and status is 0
*apfMsConnTask_0: Jan 17 14:59:57.985: [PA] c6:c7:a6:b5:2e:df processSsidIE ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_0: Jan 17 14:59:57.985: [PA] c6:c7:a6:b5:2e:df STA - rates (4): 48 72 224 108 0 0 0 0 0 0 0 0 0 0 0 0
*apfMsConnTask_0: Jan 17 14:59:57.985: [PA] c6:c7:a6:b5:2e:df suppRates statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_0: Jan 17 14:59:57.985: [PA] c6:c7:a6:b5:2e:df Assigning flex webauth IPv4-ACL ID :65535, IPv6-ACL ID:65535 for AP WLAN ID : 10
*apfMsConnTask_0: Jan 17 14:59:57.985: [PA] c6:c7:a6:b5:2e:df Allocate AID 176 slot 1 on AP bgxly-7ar-lap-4 #clients on this slot 51
*apfMsConnTask_0: Jan 17 14:59:57.985: [PA] c6:c7:a6:b5:2e:df Reassoc Req BSSID bc:26:c7:f1:14:86 AP(bgxly-7ar-lap-4) slot 1 ssid (testnew) Tmstmp 3465566 AID 176 stCode 0/0 apChngd 0 oldAp 00:00:00:00:00:00
*apfMsConnTask_0: Jan 17 14:59:57.985: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 START (0) Initializing policy
*apfMsConnTask_0: Jan 17 14:59:57.985: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 START (0) Change state to AUTHCHECK (2) last state START (0)
*apfMsConnTask_0: Jan 17 14:59:57.985: [PA] c6:c7:a6:b5:2e:df apfVapSecurity=0x2040 L2=0 SkipWeb=0
*apfMsConnTask_0: Jan 17 14:59:57.985: [PA] c6:c7:a6:b5:2e:df AuthenticationRequired = 0
*apfMsConnTask_0: Jan 17 14:59:57.985: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 AUTHCHECK (2) Change state to L2AUTHCOMPLETE (4) last state AUTHCHECK (2)
*apfMsConnTask_0: Jan 17 14:59:57.985: [PA] c6:c7:a6:b5:2e:df Not Using WMM Compliance code qosCap 00
*apfMsConnTask_0: Jan 17 14:59:57.985: [PA] c6:c7:a6:b5:2e:df flex webauth ipv4 & ipv6 acl ids to be sent when fabric is disabled:65535/65535
*apfMsConnTask_0: Jan 17 14:59:57.985: [PA] c6:c7:a6:b5:2e:df flex webauth acl id to be sent :65535 name : client acl id :65535 name :
*apfMsConnTask_0: Jan 17 14:59:57.985: [PA] c6:c7:a6:b5:2e:df flex webauth ipv6 acl id to be sent :65535 name : client acl id :65535 name :
*apfMsConnTask_0: Jan 17 14:59:57.985: [PA] c6:c7:a6:b5:2e:df Vlan while overriding the policy = -1
*apfMsConnTask_0: Jan 17 14:59:57.985: [PA] c6:c7:a6:b5:2e:df sending to spamAddMobile vlanId -1 aclName = , flexAclId 65535
*apfMsConnTask_0: Jan 17 14:59:57.985: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP bc:26:c7:f1:14:80 vapId 10 apVapId 10 flex acl-name: v6acl-name
*apfMsConnTask_0: Jan 17 14:59:57.985: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 L2AUTHCOMPLETE (4) Change state to DHCP_REQD (7) last state L2AUTHCOMPLETE (4)
*apfMsConnTask_0: Jan 17 14:59:57.985: [PA] c6:c7:a6:b5:2e:df Not sending Registration for Fabric client. Primary and Secondary MS IP is zero
*apfMsConnTask_0: Jan 17 14:59:57.985: [PA] c6:c7:a6:b5:2e:df apfMsAssoStateInc
*apfMsConnTask_0: Jan 17 14:59:57.985: [PA] c6:c7:a6:b5:2e:df apfPemAddUser2 (apf_policy.c:465) Changing state for mobile c6:c7:a6:b5:2e:df on AP bc:26:c7:f1:14:80 from Idle to Associated
*apfMsConnTask_0: Jan 17 14:59:57.985: [PA] c6:c7:a6:b5:2e:df apfPemAddUser2:session timeout forstation c6:c7:a6:b5:2e:df - Session Tout 0, apfMsTimeOut '0' and sessionTimerRunning flag is 0
*apfMsConnTask_0: Jan 17 14:59:57.985: [PA] c6:c7:a6:b5:2e:df Stopping deletion of Mobile Station: (callerId: 48)
*apfMsConnTask_0: Jan 17 14:59:57.985: [PA] c6:c7:a6:b5:2e:df Func: apfPemAddUser2, Ms Timeout = 0, Session Timeout = 0
*apfMsConnTask_0: Jan 17 14:59:57.985: [PA] c6:c7:a6:b5:2e:df Sending assoc-resp with status 0 station:c6:c7:a6:b5:2e:df AP:bc:26:c7:f1:14:80-01 on apVapId 10
*apfMsConnTask_0: Jan 17 14:59:57.985: [PA] c6:c7:a6:b5:2e:df VHT Operation IE: width 40/0 ch 36 freq0 0 freq1 0 msc0 0xff msc1 0xff
*apfMsConnTask_0: Jan 17 14:59:57.985: [PA] c6:c7:a6:b5:2e:df Sending Assoc Response (status: '0') to station on AP bgxly-7ar-lap-4 on BSSID bc:26:c7:f1:14:86 ApVapId 10 Slot 1, mobility role 0
*apfMsConnTask_0: Jan 17 14:59:57.985: [PA] c6:c7:a6:b5:2e:df apfProcessAssocReq (apf_80211.c:12998) Changing state for mobile c6:c7:a6:b5:2e:df on AP bc:26:c7:f1:14:80 from Associated to Associated
*apfMsConnTask_0: Jan 17 14:59:57.986: [PA] c6:c7:a6:b5:2e:df Mobility query, PEM State: DHCP_REQD
*apfMsConnTask_0: Jan 17 14:59:57.986: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 DHCP_REQD (7) NO release MSCB
*apfMsConnTask_0: Jan 17 14:59:57.986: [PA] c6:c7:a6:b5:2e:df Building Mobile Announce :
*apfMsConnTask_0: Jan 17 14:59:57.986: [PA] c6:c7:a6:b5:2e:df Building Client Payload:
*apfMsConnTask_0: Jan 17 14:59:57.986: [PA] c6:c7:a6:b5:2e:df Client Ip: 0.0.0.0
*apfMsConnTask_0: Jan 17 14:59:57.986: [PA] c6:c7:a6:b5:2e:df Client Vap Security: 8256
*apfMsConnTask_0: Jan 17 14:59:57.986: [PA] c6:c7:a6:b5:2e:df Virtual Ip: 10.0.0.1
*apfMsConnTask_0: Jan 17 14:59:57.986: [PA] c6:c7:a6:b5:2e:df ssid: testnew
*apfMsConnTask_0: Jan 17 14:59:57.986: [PA] c6:c7:a6:b5:2e:df Building Client profile name Payload:
*apfMsConnTask_0: Jan 17 14:59:57.986: [PA] c6:c7:a6:b5:2e:df Profile Name: testnew
*apfMsConnTask_0: Jan 17 14:59:57.986: [PA] c6:c7:a6:b5:2e:df Building VlanIpPayload.
*apfMsConnTask_0: Jan 17 14:59:57.986: [PA] c6:c7:a6:b5:2e:df Mobile Announce sent to 1 members of the local group.
*spamApTask7: Jan 17 14:59:57.986: [PA] c6:c7:a6:b5:2e:df Add SGT:0 to AP bc:26:c7:f1:14:80
*spamApTask7: Jan 17 14:59:57.986: [PA] c6:c7:a6:b5:2e:df Add CTS mobile SGT - Encoded the capwap payload for the mobile with SGT 0
*spamApTask7: Jan 17 14:59:57.986: [PA] c6:c7:a6:b5:2e:df MS IP NULL during AddMobile, not sending IP Distribution
*spamApTask7: Jan 17 14:59:57.986: [PA] c6:c7:a6:b5:2e:df Flex Ipv6 pre-auth acl is not present, not Encoding Flex Ipv6 acl for add mobile Payload
*spamApTask7: Jan 17 14:59:57.986: [PA] c6:c7:a6:b5:2e:df Successful transmission of LWAPP Add-Mobile to AP bc:26:c7:f1:14:80 slotId 1 idx@34
*spamApTask7: Jan 17 14:59:57.986: [PA] c6:c7:a6:b5:2e:df Setting ADD_MOBILE (idx 35, action 0, last count 0) ack state for STA on AP bc:26:c7:f1:14:80
*DHCP Socket Task: Jan 17 14:59:58.056: [PA] c6:c7:a6:b5:2e:df DHCP received op BOOTREQUEST (1) (len 312,vlan 228, port 8, encap 0xec03, xid 0x667c0103)
*DHCP Socket Task: Jan 17 14:59:58.056: [PA] c6:c7:a6:b5:2e:df DHCP (encap type 0xec03) mstype 0ff:ff:ff:ff:ff:ff
*DHCP Socket Task: Jan 17 14:59:58.056: [PA] c6:c7:a6:b5:2e:df DHCP dropping packet due to ongoing mobility handshake exchange, (siaddr 0.0.0.0, mobility state = 'apfMsMmQueryRequested'
*DHCP Socket Task: Jan 17 14:59:58.556: [PA] c6:c7:a6:b5:2e:df DHCP received op BOOTREQUEST (1) (len 312,vlan 228, port 8, encap 0xec03, xid 0x667c0103)
*DHCP Socket Task: Jan 17 14:59:58.556: [PA] c6:c7:a6:b5:2e:df DHCP (encap type 0xec03) mstype 0ff:ff:ff:ff:ff:ff
*DHCP Socket Task: Jan 17 14:59:58.556: [PA] c6:c7:a6:b5:2e:df DHCP dropping packet due to ongoing mobility handshake exchange, (siaddr 0.0.0.0, mobility state = 'apfMsMmQueryRequested'
*DHCP Socket Task: Jan 17 14:59:59.557: [PA] c6:c7:a6:b5:2e:df DHCP received op BOOTREQUEST (1) (len 312,vlan 228, port 8, encap 0xec03, xid 0x667c0103)
*DHCP Socket Task: Jan 17 14:59:59.557: [PA] c6:c7:a6:b5:2e:df DHCP (encap type 0xec03) mstype 0ff:ff:ff:ff:ff:ff
*DHCP Socket Task: Jan 17 14:59:59.557: [PA] c6:c7:a6:b5:2e:df DHCP dropping packet due to ongoing mobility handshake exchange, (siaddr 0.0.0.0, mobility state = 'apfMsMmQueryRequested'
*apfReceiveTask: Jan 17 15:00:00.863: [PA] c6:c7:a6:b5:2e:df Attempting anchor export for mobile c6:c7:a6:b5:2e:df
*apfReceiveTask: Jan 17 15:00:00.863: [PA] c6:c7:a6:b5:2e:df Building Client Payload:
*apfReceiveTask: Jan 17 15:00:00.863: [PA] c6:c7:a6:b5:2e:df Client Ip: 0.0.0.0
*apfReceiveTask: Jan 17 15:00:00.863: [PA] c6:c7:a6:b5:2e:df Client Vap Security: 8256
*apfReceiveTask: Jan 17 15:00:00.863: [PA] c6:c7:a6:b5:2e:df Virtual Ip: 10.0.0.1
*apfReceiveTask: Jan 17 15:00:00.863: [PA] c6:c7:a6:b5:2e:df ssid: testnew
*apfReceiveTask: Jan 17 15:00:00.863: [PA] c6:c7:a6:b5:2e:df Building Client profile name Payload:
*apfReceiveTask: Jan 17 15:00:00.863: [PA] c6:c7:a6:b5:2e:df Profile Name: testnew
*apfReceiveTask: Jan 17 15:00:00.863: [PA] c6:c7:a6:b5:2e:df Building policy payload
*apfReceiveTask: Jan 17 15:00:00.863: [PA] c6:c7:a6:b5:2e:df mmAnchorExportSend: Building ExportForeignLradMac Payload Lrad Mac: bc:26:c7:f1:14:80
*apfReceiveTask: Jan 17 15:00:00.863: [PA] c6:c7:a6:b5:2e:df Created Cisco-Audit-Session-ID for the mobile: 28dde0220007d2d665a79e18 type: local
*apfReceiveTask: Jan 17 15:00:00.863: [PA] c6:c7:a6:b5:2e:df Building Audit session ID (28dde0220007d2d665a79e18) payload in Mobility handoff
*apfReceiveTask: Jan 17 15:00:00.863: [PA] c6:c7:a6:b5:2e:df Building IPv6 Client Payload:
*apfReceiveTask: Jan 17 15:00:00.863: [PA] c6:c7:a6:b5:2e:df mmBuildIPv6ClientPayload: IPv6: Built IPv6 client payload vlan =228, numIPv6Addr =0
*apfReceiveTask: Jan 17 15:00:00.863: [PA] c6:c7:a6:b5:2e:df SGT Payload buiding in handoff 0 (len 6)
*apfReceiveTask: Jan 17 15:00:00.863: [PA] c6:c7:a6:b5:2e:df SGT Payload built in Export Anchor Req 0
*apfReceiveTask: Jan 17 15:00:00.864: [PA] c6:c7:a6:b5:2e:df Export Anchor request sent to 10.208.134.212
*mmMobility: Jan 17 15:00:01.855: [PA] c6:c7:a6:b5:2e:df Mobility Anchor packet retry: Peer IP: 10.208.134.212, Anchor IP: 0.0.0.0
*mmMobility: Jan 17 15:00:02.847: [PA] c6:c7:a6:b5:2e:df Mobility Anchor packet retry: Peer IP: 10.208.134.212, Anchor IP: 0.0.0.0
*apfReceiveTask: Jan 17 15:00:03.839: [PA] c6:c7:a6:b5:2e:df apfMmProcessResponse: Got Anchor Close from mmMipAnchorResendTimeoutHandler for mobile c6:c7:a6:b5:2e:df, delete mobile. reason code = 2 MmRole : 0
*apfReceiveTask: Jan 17 15:00:03.839: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 DHCP_REQD (7) mobility role update request from Unassociated to Handoff
*apfReceiveTask: Jan 17 15:00:03.839: [PA] c6:c7:a6:b5:2e:df IP Addr Clear. AP MAC[bc:26:c7:f1:14:80] Role[Unassociated] Pem State [DHCP_REQD] Connected Time[6]
*apfReceiveTask: Jan 17 15:00:03.839: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 DHCP_REQD (7) Reached ERROR: from line 7760
*apfReceiveTask: Jan 17 15:00:03.839: [PA] c6:c7:a6:b5:2e:df apfMmProcessCloseResponse (apf_mm.c:723) Expiring Mobile!
*apfReceiveTask: Jan 17 15:00:03.839: [PA] c6:c7:a6:b5:2e:df apfMsExpireMobileStation (apf_ms.c:8142) Changing state for mobile c6:c7:a6:b5:2e:df on AP bc:26:c7:f1:14:80 from Associated to Disassociated
*apfReceiveTask: Jan 17 15:00:03.839: [PA] c6:c7:a6:b5:2e:df apfMsAssoStateDec
*apfReceiveTask: Jan 17 15:00:03.839: [PA] c6:c7:a6:b5:2e:df apfMsExpireMobileStation (apf_ms.c:8294) Changing state for mobile c6:c7:a6:b5:2e:df on AP bc:26:c7:f1:14:80 from Disassociated to Idle
*apfReceiveTask: Jan 17 15:00:03.839: [PA] c6:c7:a6:b5:2e:df pemApfDeleteMobileStation2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfReceiveTask: Jan 17 15:00:03.839: [PA] c6:c7:a6:b5:2e:df the value of url acl preserve flag is 0 for mobile c6:c7:a6:b5:2e:df (caller pem_api.c:5292)
*apfReceiveTask: Jan 17 15:00:03.839: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 DHCP_REQD (7) Deleted mobile LWAPP rule on AP [bc:26:c7:f1:14:80]
*apfReceiveTask: Jan 17 15:00:03.839: [PA] c6:c7:a6:b5:2e:df Succesfully freed AID 176, slot 1 on AP bc:26:c7:f1:14:80, #client on this slot 51
*spamApTask7: Jan 17 15:00:03.839: [PA] c6:c7:a6:b5:2e:df Setting DEL_MOBILE (seqno 0, action 6) ack state for STA on AP bc:26:c7:f1:14:80
*spamApTask7: Jan 17 15:00:03.839: [PA] c6:c7:a6:b5:2e:df Setting ADD_MOBILE (idx 38, seqno 127, action 6, count 127, last count 127) ack state for STA on AP bc:26:c7:f1:14:80
*spamApTask7: Jan 17 15:00:03.839: [PA] c6:c7:a6:b5:2e:df Delete Mobile request with reason 'MN_DEL_PEM_CLEANUP' on slot 1 sent to the AP bc:26:c7:f1:14:80 IP: 40.221.225.47:5256.
*apfReceiveTask: Jan 17 15:00:03.839: [PA] c6:c7:a6:b5:2e:df Deleting mobile on AP bc:26:c7:f1:14:80(1)
*apfReceiveTask: Jan 17 15:00:03.839: [PA] c6:c7:a6:b5:2e:df apf_ms.c:5636 Clearing the SGT 0 of mobile
*apfReceiveTask: Jan 17 15:00:03.839: [PA] c6:c7:a6:b5:2e:df Decrement the SGT 0 policy count reference by the clients 1974
*spamApTask7: Jan 17 15:00:03.842: [PA] c6:c7:a6:b5:2e:df Received add/del ack packet with sequence number: got 127 expected 127 action = 6
*spamApTask7: Jan 17 15:00:03.842: [PA] c6:c7:a6:b5:2e:df Received DELETE mobile, reasonCode UNKNOWN, deleteReason 15 from AP bc:26:c7:f1:14:80, slot 1 ...cleaning up mscb
*Dot1x_NW_MsgTask_2: Jan 17 15:00:07.288: [PA] 1x: EAPOL frame with dst MAC 5c:5a:c7:cc:75:60 and BSSID 24:36:da:5d:f9:e0 discarded
(Cisco Controller) >debug *apfOpenDtlSocket: Jan 17 15:00:28.192: [PA] c6:c7:a6:b5:2e:df Received management frame ASSOCIATION REQUEST on BSSID bc:26:c7:f1:14:86 destination addr bc:26:c7:f1:14:86 slotid 1
*apfMsConnTask_0: Jan 17 15:00:28.192: [PA] c6:c7:a6:b5:2e:df Updating the client capabiility as 5
*apfMsConnTask_0: Jan 17 15:00:28.192: [PA] c6:c7:a6:b5:2e:df Processing assoc-req station:c6:c7:a6:b5:2e:df AP:bc:26:c7:f1:14:80-01 ssid : testnew thread:257bb358
*apfMsConnTask_0: Jan 17 15:00:28.193: [PA] c6:c7:a6:b5:2e:df apfCreateMobileStationEntryWrapper (apf_ms.c:4510) Changing state for mobile c6:c7:a6:b5:2e:df on AP bc:26:c7:f1:14:80 from Idle to Idle
*apfMsConnTask_0: Jan 17 15:00:28.193: [PA] c6:c7:a6:b5:2e:df Adding mobile on LWAPP AP bc:26:c7:f1:14:80(1)
*apfMsConnTask_0: Jan 17 15:00:28.193: [PA] c6:c7:a6:b5:2e:df Created Acct-Session-ID (65a79e34/c6:c7:a6:b5:2e:df/523078) for the mobile
*apfMsConnTask_0: Jan 17 15:00:28.194: [PA] c6:c7:a6:b5:2e:df Setting hasApChnaged Flag as true. It is a fresh assoc request.
*apfMsConnTask_0: Jan 17 15:00:28.194: [PA] c6:c7:a6:b5:2e:df req rcv on open Wlan
*apfMsConnTask_0: Jan 17 15:00:28.194: [PA] c6:c7:a6:b5:2e:df Setting RTTS enabled to 0
*apfMsConnTask_0: Jan 17 15:00:28.194: [PA] c6:c7:a6:b5:2e:df Association received from mobile on BSSID bc:26:c7:f1:14:86 AP bgxly-7ar-lap-4
*apfMsConnTask_0: Jan 17 15:00:28.194: [PA] c6:c7:a6:b5:2e:df Station: c6:c7:a6:b5:2e:df 11v BSS Transition not enabled on the AP BC:26:C7:F1:14:80
*apfMsConnTask_0: Jan 17 15:00:28.194: [PA] c6:c7:a6:b5:2e:df Global 200 Clients are allowed to AP radio
*apfMsConnTask_0: Jan 17 15:00:28.194: [PA] c6:c7:a6:b5:2e:df Max Client Trap Threshold: 0 cur: 50
*apfMsConnTask_0: Jan 17 15:00:28.194: [PA] c6:c7:a6:b5:2e:df Rf profile 600 Clients are allowed to AP wlan
*apfMsConnTask_0: Jan 17 15:00:28.194: [PA] c6:c7:a6:b5:2e:df Updated local bridging VLAN to 228 while applying WLAN policy
*apfMsConnTask_0: Jan 17 15:00:28.194: [PA] c6:c7:a6:b5:2e:df Updated session timeout to 0 and Sleep timeout to 720 while applying WLAN policy
*apfMsConnTask_0: Jan 17 15:00:28.194: [PA] c6:c7:a6:b5:2e:df Applying Interface(management) policy on Mobile, role Unassociated. Ms NAC State 0 Quarantine Vlan 0 Access Vlan 0
*apfMsConnTask_0: Jan 17 15:00:28.194: [PA] c6:c7:a6:b5:2e:df Re-applying interface (management) policy for client
*apfMsConnTask_0: Jan 17 15:00:28.194: [PA] c6:c7:a6:b5:2e:df After applying Interface(management) policy on Mobile, role Unassociated. Ms NAC State 2 Quarantine Vlan 0 Access Vlan 228
*apfMsConnTask_0: Jan 17 15:00:28.194: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 START (0) Changing IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:3498)
*apfMsConnTask_0: Jan 17 15:00:28.194: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 START (0) Changing Url ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255),Default action is '0' --- (caller apf_policy.c:3518)
*apfMsConnTask_0: Jan 17 15:00:28.194: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 START (0) Changing IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:3539)
*apfMsConnTask_0: Jan 17 15:00:28.194: [PA] c6:c7:a6:b5:2e:df Values before applying NASID - interfacetype:0, ovrd:0, mscb nasid:, interface nasid:, APgrpset:0
*apfMsConnTask_0: Jan 17 15:00:28.194: [PA] c6:c7:a6:b5:2e:df apfApplyWlanPolicy: Apply WLAN Policy over PMIPv6 Client Mobility Type, Tunnel User - 0
*apfMsConnTask_0: Jan 17 15:00:28.194: [PA] c6:c7:a6:b5:2e:df Check before Setting the NAS Id to WLAN specific Id ''
*apfMsConnTask_0: Jan 17 15:00:28.194: [PA] c6:c7:a6:b5:2e:df apf_policy.c:2783 Assigning the SGT 0 to mobile (earlier sgt 0)
*apfMsConnTask_0: Jan 17 15:00:28.194: [PA] c6:c7:a6:b5:2e:df Increment the SGT 0 policy count reference by the clients 1982
*apfMsConnTask_0: Jan 17 15:00:28.194: [PA] c6:c7:a6:b5:2e:df Check the client SGT 0 policy and push it to AP bc:26:c7:f1:14:80
*apfMsConnTask_0: Jan 17 15:00:28.195: [PA] c6:c7:a6:b5:2e:df In processSsidIE:7634 setting Central switched to TRUE
*apfMsConnTask_0: Jan 17 15:00:28.195: [PA] c6:c7:a6:b5:2e:df In processSsidIE:7637 apVapId = 10 and Split Acl Id = 65535
*apfMsConnTask_0: Jan 17 15:00:28.195: [PA] c6:c7:a6:b5:2e:df Applying site-specific Local Bridging override for station c6:c7:a6:b5:2e:df - vapId 10, site 'default-group', interface 'management'
*apfMsConnTask_0: Jan 17 15:00:28.195: [PA] c6:c7:a6:b5:2e:df Applying Local Bridging Interface Policy for station c6:c7:a6:b5:2e:df - vlan 228, interface id 0, interface 'management', nasId:''
*apfMsConnTask_0: Jan 17 15:00:28.195: [PA] c6:c7:a6:b5:2e:df processSsidIE statusCode is 0 and status is 0
*apfMsConnTask_0: Jan 17 15:00:28.195: [PA] c6:c7:a6:b5:2e:df processSsidIE ssid_done_flag is 0 finish_flag is 0
*apfMsConnTask_0: Jan 17 15:00:28.195: [PA] c6:c7:a6:b5:2e:df STA - rates (4): 48 72 224 108 0 0 0 0 0 0 0 0 0 0 0 0
*apfMsConnTask_0: Jan 17 15:00:28.195: [PA] c6:c7:a6:b5:2e:df suppRates statusCode is 0 and gotSuppRatesElement is 1
*apfMsConnTask_0: Jan 17 15:00:28.195: [PA] c6:c7:a6:b5:2e:df Assigning flex webauth IPv4-ACL ID :65535, IPv6-ACL ID:65535 for AP WLAN ID : 10
*apfMsConnTask_0: Jan 17 15:00:28.195: [PA] c6:c7:a6:b5:2e:df Allocate AID 177 slot 1 on AP bgxly-7ar-lap-4 #clients on this slot 51
*apfMsConnTask_0: Jan 17 15:00:28.195: [PA] c6:c7:a6:b5:2e:df Assoc Req BSSID bc:26:c7:f1:14:86 AP(bgxly-7ar-lap-4) slot 1 ssid (testnew) Tmstmp 3465596 AID 177 stCode 0/0 apChngd 0 oldAp 00:00:00:00:00:00
*apfMsConnTask_0: Jan 17 15:00:28.195: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 START (0) Initializing policy
*apfMsConnTask_0: Jan 17 15:00:28.195: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 START (0) Change state to AUTHCHECK (2) last state START (0)
*apfMsConnTask_0: Jan 17 15:00:28.195: [PA] c6:c7:a6:b5:2e:df apfVapSecurity=0x2040 L2=0 SkipWeb=0
*apfMsConnTask_0: Jan 17 15:00:28.195: [PA] c6:c7:a6:b5:2e:df AuthenticationRequired = 0
*apfMsConnTask_0: Jan 17 15:00:28.195: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 AUTHCHECK (2) Change state to L2AUTHCOMPLETE (4) last state AUTHCHECK (2)
*apfMsConnTask_0: Jan 17 15:00:28.195: [PA] c6:c7:a6:b5:2e:df Not Using WMM Compliance code qosCap 00
*apfMsConnTask_0: Jan 17 15:00:28.195: [PA] c6:c7:a6:b5:2e:df flex webauth ipv4 & ipv6 acl ids to be sent when fabric is disabled:65535/65535
*apfMsConnTask_0: Jan 17 15:00:28.195: [PA] c6:c7:a6:b5:2e:df flex webauth acl id to be sent :65535 name : client acl id :65535 name :
*apfMsConnTask_0: Jan 17 15:00:28.195: [PA] c6:c7:a6:b5:2e:df Vlan while overriding the policy = -1
*apfMsConnTask_0: Jan 17 15:00:28.195: [PA] c6:c7:a6:b5:2e:df sending to spamAddMobile vlanId -1 aclName = , flexAclId 65535
*apfMsConnTask_0: Jan 17 15:00:28.195: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP bc:26:c7:f1:14:80 vapId 10 apVapId 10 flex acl-name: v6acl-name
*apfMsConnTask_0: Jan 17 15:00:28.195: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 L2AUTHCOMPLETE (4) Change state to DHCP_REQD (7) last state L2AUTHCOMPLETE (4)
*apfMsConnTask_0: Jan 17 15:00:28.195: [PA] c6:c7:a6:b5:2e:df Not sending Registration for Fabric client. Primary and Secondary MS IP is zero
*apfMsConnTask_0: Jan 17 15:00:28.195: [PA] c6:c7:a6:b5:2e:df apfMsAssoStateInc
*apfMsConnTask_0: Jan 17 15:00:28.195: [PA] c6:c7:a6:b5:2e:df apfPemAddUser2 (apf_policy.c:465) Changing state for mobile c6:c7:a6:b5:2e:df on AP bc:26:c7:f1:14:80 from Idle to Associated
*apfMsConnTask_0: Jan 17 15:00:28.195: [PA] c6:c7:a6:b5:2e:df apfPemAddUser2:session timeout forstation c6:c7:a6:b5:2e:df - Session Tout 0, apfMsTimeOut '0' and sessionTimerRunning flag is 0
*apfMsConnTask_0: Jan 17 15:00:28.195: [PA] c6:c7:a6:b5:2e:df Stopping deletion of Mobile Station: (callerId: 48)
*apfMsConnTask_0: Jan 17 15:00:28.195: [PA] c6:c7:a6:b5:2e:df Func: apfPemAddUser2, Ms Timeout = 0, Session Timeout = 0
*apfMsConnTask_0: Jan 17 15:00:28.195: [PA] c6:c7:a6:b5:2e:df Sending assoc-resp with status 0 station:c6:c7:a6:b5:2e:df AP:bc:26:c7:f1:14:80-01 on apVapId 10
*apfMsConnTask_0: Jan 17 15:00:28.195: [PA] c6:c7:a6:b5:2e:df VHT Operation IE: width 40/0 ch 36 freq0 0 freq1 0 msc0 0xff msc1 0xff
*apfMsConnTask_0: Jan 17 15:00:28.195: [PA] c6:c7:a6:b5:2e:df Sending Assoc Response (status: '0') to station on AP bgxly-7ar-lap-4 on BSSID bc:26:c7:f1:14:86 ApVapId 10 Slot 1, mobility role 0
*apfMsConnTask_0: Jan 17 15:00:28.195: [PA] c6:c7:a6:b5:2e:df apfProcessAssocReq (apf_80211.c:12998) Changing state for mobile c6:c7:a6:b5:2e:df on AP bc:26:c7:f1:14:80 from Associated to Associated
*apfMsConnTask_0: Jan 17 15:00:28.195: [PA] c6:c7:a6:b5:2e:df Mobility query, PEM State: DHCP_REQD
*apfMsConnTask_0: Jan 17 15:00:28.195: [PA] c6:c7:a6:b5:2e:df 0.0.0.0 DHCP_REQD (7) NO release MSCB
*apfMsConnTask_0: Jan 17 15:00:28.196: [PA] c6:c7:a6:b5:2e:df Building Mobile Announce :
*apfMsConnTask_0: Jan 17 15:00:28.196: [PA] c6:c7:a6:b5:2e:df Building Client Payload:
*apfMsConnTask_0: Jan 17 15:00:28.196: [PA] c6:c7:a6:b5:2e:df Client Ip: 0.0.0.0
*apfMsConnTask_0: Jan 17 15:00:28.196: [PA] c6:c7:a6:b5:2e:df Client Vlan Ip: 40.221.224.34, Vlan mask : 255.255.224.0
*apfMsConnTask_0: Jan 17 15:00:28.196: [PA] c6:c7:a6:b5:2e:df Client Vap Security: 8256
*apfMsConnTask_0: Jan 17 15:00:28.196: [PA] c6:c7:a6:b5:2e:df Virtual Ip: 10.0.0.1
*apfMsConnTask_0: Jan 17 15:00:28.196: [PA] c6:c7:a6:b5:2e:df ssid: testnew
*apfMsConnTask_0: Jan 17 15:00:28.196: [PA] c6:c7:a6:b5:2e:df Building Client profile name Payload:
*apfMsConnTask_0: Jan 17 15:00:28.196: [PA] c6:c7:a6:b5:2e:df Profile Name: testnew
*apfMsConnTask_0: Jan 17 15:00:28.196: [PA] c6:c7:a6:b5:2e:df Building VlanIpPayload.
*apfMsConnTask_0: Jan 17 15:00:28.196: [PA] c6:c7:a6:b5:2e:df Mobile Announce sent to 1 members of the local group.
*spamApTask7: Jan 17 15:00:28.196: [PA] c6:c7:a6:b5:2e:df Add SGT:0 to AP bc:26:c7:f1:14:80
*spamApTask7: Jan 17 15:00:28.196: [PA] c6:c7:a6:b5:2e:df Add CTS mobile SGT - Encoded the capwap payload for the mobile with SGT 0
*spamApTask7: Jan 17 15:00:28.196: [PA] c6:c7:a6:b5:2e:df MS IP NULL during AddMobile, not sending IP Distribution
*spamApTask7: Jan 17 15:00:28.196: [PA] c6:c7:a6:b5:2e:df Flex Ipv6 post auth acl is not present, not updating add mobile Payload
*spamApTask7: Jan 17 15:00:28.196: [PA] c6:c7:a6:b5:2e:df Successful transmission of LWAPP Add-Mobile to AP bc:26:c7:f1:14:80 slotId 1 idx@44
*spamApTask7: Jan 17 15:00:28.196: [PA] c6:c7:a6:b5:2e:df Setting ADD_MOBILE (idx 45, action 0, last count 0) ack state for STA on AP bc:26:c7:f1:14:80
*apfOpenDtlSocket: Jan 17 15:00:28.226: [PA] c6:c7:a6:b5:2e:df Received management frame ACTION on BSSID bc:26:c7:f1:14:86 destination addr bc:26:c7:f1:14:86 slotid 1
*apfMsConnTask_0: Jan 17 15:00:28.226: [PA] c6:c7:a6:b5:2e:df Got action frame from the client (ActionCategory:5), payloadLen:12
*apfMsConnTask_0: Jan 17 15:00:28.226: [PA] c6:c7:a6:b5:2e:df Found RM action category code
*apfMsConnTask_0: Jan 17 15:00:28.226: [PA] c6:c7:a6:b5:2e:df Station: c6:c7:a6:b5:2e:df sent 802.11K neighbor request to AP BC:26:C7:F1:14:80
*apfMsConnTask_0: Jan 17 15:00:28.226: [PA] c6:c7:a6:b5:2e:df Station: c6:c7:a6:b5:2e:df requested neighbors on non XOR roam capable AP BC:26:C7:F1:14:80 Slot 1
d*DHCP Socket Task: Jan 17 15:00:28.469: [PA] c6:c7:a6:b5:2e:df DHCP received op BOOTREQUEST (1) (len 314,vlan 228, port 8, encap 0xec03, xid 0xb8f0badc)
*DHCP Socket Task: Jan 17 15:00:28.469: [PA] c6:c7:a6:b5:2e:df DHCP (encap type 0xec03) mstype 0ff:ff:ff:ff:ff:ff
*DHCP Socket Task: Jan 17 15:00:28.469: [PA] c6:c7:a6:b5:2e:df DHCP dropping packet due to ongoing mobility handshake exchange, (siaddr 0.0.0.0, mobility state = 'apfMsMmQueryRequested'
is*DHCP Socket Task: Jan 17 15:00:28.968: [PA] c6:c7:a6:b5:2e:df DHCP received op BOOTREQUEST (1) (len 314,vlan 228, port 8, encap 0xec03, xid 0xb8f0badc)
*DHCP Socket Task: Jan 17 15:00:28.968: [PA] c6:c7:a6:b5:2e:df DHCP (encap type 0xec03) mstype 0ff:ff:ff:ff:ff:ff
*DHCP Socket Task: Jan 17 15:00:28.968: [PA] c6:c7:a6:b5:2e:df DHCP dropping packet due to ongoing mobility handshake exchange, (siaddr 0.0.0.0, mobility state = 'apfMsMmQueryRequested'
able-all *DHCP Socket Task: Jan 17 15:00:29.474: [PA] c6:c7:a6:b5:2e:df DHCP received op BOOTREQUEST (1) (len 314,vlan 228, port 8, encap 0xec03, xid 0xb8f0badc)
*DHCP Socket Task: Jan 17 15:00:29.474: [PA] c6:c7:a6:b5:2e:df DHCP (encap type 0xec03) mstype 0ff:ff:ff:ff:ff:ff
*DHCP Socket Task: Jan 17 15:00:29.474: [PA] c6:c7:a6:b5:2e:df DHCP dropping packet due to ongoing mobility handshake exchange, (siaddr 0.0.0.0, mobility state = 'apfMsMmQueryRequested'
6 Replies 6
marce1000
  - Review these https://bst.cloudapps.cisco.com/bugsearch?pf=prdNm&kw=dropping%20packet%20due%20to%20ongoing%20mobility%20handshake&bt=custV&sb=anfr
       -  You are not mentioning the controller models involved but look into :
                  https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html
                    - Have the debugging output which you posted  analyzed with : Wireless Debug Analyzer
 M.
networklearner1
Hello @marce1000 the foreign WLC is 3504 model running on 8.10.185.0 version and the Anchor is 5508 running on 8.5.161.7
The mobility profile gets created on the anchor. When I see the DHCP (Infoblox), it is offering the IP but then nothing happens.
 - For 5508 go for     https://software.cisco.com/download/specialrelease/2702eede2b47a5c3bb40795bbe836af6 ,
   (Added) 3504 ;->  https://software.cisco.com/download/home/286312601/type/280926587/release/8.10.190.0
                    For the rest take care of the items mention in my initial reply!
 M.
marce1000
 - (Added2 reply) : Below is the output from the debug session which you posted when analyzed with Wireless Debug Analyzer
                             Show All flag was checked
   It would also be advisable to have a checkup of the configuration of both controllers according to :
            WirelessAnalyzer input (procedure) for AireOs controllers
                                            Have the output analyzed with : Wireless Config Analyzer
TimeTaskTranslated
Connection attempt #1
Connection attempt #2
Jan 17 14:59:42.883 *apfMsConnTask_0 Client made new Association to AP/BSSID BSSID bc:26:c7:f1:14:86 AP bgxly-7ar-lap-4
Jan 17 14:59:42.884 *apfMsConnTask_0 Client has entered DHCP Required state
Jan 17 14:59:42.884 *apfMsConnTask_0 Client has successfully cleared AP association phase
Jan 17 14:59:42.884 *apfMsConnTask_0 WLC/AP is sending an Association Response to the client with status code 0 = Successful association
Jan 17 14:59:43.072 *DHCP Socket Task Received DHCP request from client
Jan 17 14:59:43.571 *DHCP Socket Task Received DHCP request from client
Jan 17 14:59:44.099 *DHCP Socket Task Received DHCP request from client
Jan 17 14:59:44.598 *DHCP Socket Task Received DHCP request from client
Jan 17 14:59:45.598 *DHCP Socket Task Received DHCP request from client
Jan 17 14:59:45.991 *DHCP Socket Task Received DHCP request from client
Jan 17 14:59:46.491 *DHCP Socket Task Received DHCP request from client
Jan 17 14:59:46.492 *DHCP Socket Task Received DHCP request from client
Jan 17 14:59:47.492 *DHCP Socket Task Received DHCP request from client
Jan 17 14:59:48.764 *apfReceiveTask Client session has timed out
Connection attempt #3
Jan 17 14:59:50.637 *apfMsConnTask_0 Client roamed to AP/BSSID BSSID bc:26:c7:f1:14:89 AP bgxly-7ar-lap-4
Jan 17 14:59:50.638 *apfMsConnTask_0 Client has entered DHCP Required state
Jan 17 14:59:50.638 *apfMsConnTask_0 Client has successfully cleared AP association phase
Jan 17 14:59:50.638 *apfMsConnTask_0 WLC/AP is sending an Association Response to the client with status code 0 = Successful association
Jan 17 14:59:56.499 *apfReceiveTask Client session has timed out
Connection attempt #4
Jan 17 14:59:57.984 *apfMsConnTask_0 Client roamed to AP/BSSID BSSID bc:26:c7:f1:14:86 AP bgxly-7ar-lap-4
Jan 17 14:59:57.985 *apfMsConnTask_0 Client has entered DHCP Required state
Jan 17 14:59:57.985 *apfMsConnTask_0 Client has successfully cleared AP association phase
Jan 17 14:59:57.985 *apfMsConnTask_0 WLC/AP is sending an Association Response to the client with status code 0 = Successful association
Jan 17 14:59:58.056 *DHCP Socket Task Received DHCP request from client
Jan 17 14:59:58.556 *DHCP Socket Task Received DHCP request from client
Jan 17 14:59:59.557 *DHCP Socket Task Received DHCP request from client
Jan 17 15:00:03.839 *apfReceiveTask Client session has timed out
Connection attempt #5
Jan 17 15:00:28.194 *apfMsConnTask_0 Client made new Association to AP/BSSID BSSID bc:26:c7:f1:14:86 AP bgxly-7ar-lap-4
Jan 17 15:00:28.195 *apfMsConnTask_0 Client has entered DHCP Required state
Jan 17 15:00:28.195 *apfMsConnTask_0 Client has successfully cleared AP association phase
Jan 17 15:00:28.195 *apfMsConnTask_0 WLC/AP is sending an Association Response to the client with status code 0 = Successful association
Jan 17 15:00:28.469 *DHCP Socket Task Received DHCP request from client
Jan 17 15:00:28.968 *DHCP Socket Task Received DHCP request from client
Jan 17 15:00:29.474 *DHCP Socket Task Received DHCP request from client
networklearner1
Thank you, will check the configs in both WLCs.
                                                       >...Thank you, will check the configs in both WLCs.
  - Good work , upgrading to latest advisory release(s) becomes important too because the aireos based platforms are getting outdated , it becomes more important to run the latest/last release that they can run , because TAC support is diminishing (e.g.) ,
 M.
