dhcp on wireless ssid's ?
pcfreak49
I have a question I would like different DHCP server on my wireless ssid's set with vlan's how you do that ?
8 Replies 8
Surendra BG
yes you can do it.. Configure the DHCP pool on any Layer 3 device and under the SSID, map the respective VLAN.. this will help you..
that is..
SSID one
vlan 1
end
ssid two
vlan 2
end
make sure the AP conecting to the switchport should allow both the vlans (trunk port)
or even the below link mat help you as well
https://supportforums.cisco.com/docs/DOC-14496
lemme know if this answered your question..
Surendra
Please dont forget to rate the posts which answered your question and mark it as answered or was helpfull
Surendra BG
I want ethernet ports ip address other then get the wireless Sidd's
SSID so that each has a different IP range and also Ethernet
Ethernet switchport whould be mapped to respective vlan then.. and on the SSID map other vlan.. this will do that job..
Surendra
Surendra BG
can you tell me what all I need to configure when and where it is possible
First let's figure out what it is exactly you are trying to accomplish.  Then we will go from there.
Are you saying that you want to hand out different DCHP IP adresses on the wireless SSIDs than the IP adresses of the wired network?
Scott
Please rate this post if you found it helpful.
To this I mean I do not know if this is possible
Ethernet interfaces
ip range 10.10.10.0 255,255,255,248
vlan 1
One ssid
Vlan 2
Authentication open
Mbssid Guest mode
ip range 20.20.20.0 255,255,255,248
ssid two
Vlan 3
Authentication open
Mbssid Guest mode
Where do you have your DHCP server? On the connected switch or another external DHCP server?
Under which vlan do you have the BVI interface of the AP?
Maithri
the router itself, I would dhcp lease from parts of different ssid "
Example
One ssid
vlan 2
ssid two
30.30.30.0 255,255,255,248
vlan 3
that's the idea but do not know how it works
