01-26-2011 09:51 PM - edited 07-03-2021 07:43 PM
Hello to all,
I have a Problem with some 1252 AP.
We have installed in a Branch two 4402 (25) Controller. Both Controller work without Problems. We have also installed some other AP´s on this Controller.
Version is 7.0.98
Now my Problem. I Connect a AP´s to a HP Switch but the AP dos not get a IP.
I can see with a console Cable that is a message: AP can not join to the Controller because he has no IP.
In The DHCP is a Reservation for this AP. When i delete this Reservation the AP dosn´t also get a IP.
We have flashed this AP bot without result.
Dos anyone know this Problem?
Thanks for your help.
Andreas
01-26-2011 10:48 PM
Plug your PC into that port (where the ap is at), can you pull an IP on your PC?
01-27-2011 12:37 AM
Hi George Stefanick
thanks for your answer.
I get a IP with a PC. This is not a Problem.
01-27-2011 06:00 AM
Is it getting an IP, but just not finding the controller? Can you capture the output and post it ?
02-07-2011 09:44 PM
Hi Stefanick,
thanks for you Answer. I have found the Problem. On this AP was the Network Modul defect. Cisco change this AP.
Thanks for you Help.
Andreas
