DHCP problem in Controller
sudeesh79
Level 3
Level 3
Hi all
I hav econfigured 11 Wlan on Cisco 4404 Controller and DHCP pool for each WLAN, and 2 SSIDs
a) ABCD_Guest -- to connect guest
B) ABCD_INTERNAL -- contains 11 WLANS ( how can I get DHCP IP from these each wLANs from different pools based on the password (Network -key) user is providing. If am using NAC for authenticating user .
Anyone knows the configuration....
Please help me
amritpatek
Level 11
Level 11
Here is the URL for the configuration for the DHCP follow the configuration guide which will help you in configuration and troubleshooting :
http://www.cisco.com/en/US/docs/wireless/controller/4.2/configuration/guide/c42wlan.html#wp1108101
