DHCP scope wireless controller
bruce.thornton
Level 2
Level 2
Is there a limit to the size of a scopes defined on 5508 controller, is it best practice to do this. Should it be placed on real DHCP server. I have this defined for Guest Wireless Internet.
Hi @bruce.thornton
 Certailing would be much better if you can have a real DHCP server. Even an IOS device like a swtich could be better. WLC DHCP is for small network and has some limitation depends on the environment.
 But, there´s no limitation on the size of the DHCP scope.
-If I helped you somehow, please, rate it as useful.-
