DHCP
Network Pro
Level 7
Level 7
we have a few access points connected to a 2960 cisco switch which in turns connects to 3560 Layer 3 switch
there are two vlans (vlan 1 (192.168.10.0) and vlan2 (192.168.20.0) )..currently all users (including wireless) users are on vlan 1  which gets ip froma Novell dhcp server. i have moved all the access points onto the 192.168.20.11 - 192.168.20.20 (!0 access points).  now dhcp for wireless users need to provided by the switch (3560) which is directly connected to 2960 switch (trunk mode)....but somehow the users seem to get ip from the 192.168.10.0 range..
this is the config on the 2960 switch
int range fa0/1-24
switchport mode trunk
switchport trunk encap dotq
switchport allowed vlan10,20
switchport mode access 20
however on giving the command (switchport trunk native vlan20) seems to work? any idea
int range fa0/1-24
nikhilcherian
Level 8
Level 8
Does your client pool include both wireless and wired
Your interface config is bit confusing, it has a trunking encapsulation as well as an access vlan . Can you configure the port either as trunk or as an access port
NikhiL
