Difference between 2802i-B-K9 and 2808i-E-K9
p.j.jennings
Hi All
Can someone tell me what the difference is between a 2802i-B-K9 and a 2802i-E-K9?
Many thanks
Phil
Ric Beeching
Level 7
Level 7
The letters stand for the regulatory domain the AP can be used in with each country adhering to different ones.
In the US for example, I believe it is 'A' or 'B' now. In Australia it is 'N' or 'Z' and E would be Europe. What country are you in?
Ric
Please rate helpful / correct posts
Thanks for the quick reply. I'm in the UK.
Cheers
Phil
No probs that is 'E' for sure. This link is really good for looking up your country domain:
https://www.cisco.com/c/dam/assets/prod/wireless/wireless-compliance-tool/index.html
Note: England comes under 'U.K' when searching.
Ric
Can the region be changed from a B to E?
I've found an AP on eBay UK but it's a 2802i-B-K9.
Phil
