Showing results forĀ
Search instead forĀ
Did you mean:Ā
Difference between 6500 series WLSM & 6500 series WiSM.
selvaaaaa
Hi  , I would like to know the difference between 6500 series WLSM & 6500 series WiSM.
& also let me know, how many controllers will be physically inside the 6500 series WiSM.
Prasan Venky
Level 3
Level 3
Thanks venky,
can you please give the difference in a clear manner ( bullet points) .
By this 2 links , i was not able to conclude it.
Simple.... WLSM manages autonomous AP's and is end of support and the WiSM manages lightweight access points and can use up to v7.0.x. The WiSM2 is the newer model that can use the latest software which as of right now is v7.4.
-Scott
Abhishek Abhishek
Hello Selvaraj,
As per your query i can suggest you the following solution-
WLSM and WiSM are two completely different architectures, and seamless
mobility between them, if at all possible would probably not be worth the
effort.
For more information please refer to the link-
http://www.cisco.com/en/US/products/hw/modules/ps2706/products_configuration_example09186a008073614c.shtml
Hope this will help you.
