PEAP authentication for laptops
vijay kumar
Level 5
Level 5
Hi All,
We have created SSID with 802.1x authentication with WPA2 AES encrytion(Broadcast) . When I am trying to access the SSID in my Android , apple mobile it is directly asking for username and password . And it is getting authenticated .
Whereas in windows 7 laptop , I need to create the SSID profile(and need to choose the security type and all) for associating to that . Is there anyway that client will be able to connect without any SSID profling configuration in laptop ?..
Thanks ,
Vijay.
7 Replies 7
Stephen Rodriguez
If they are corporate devices, you can use a GPO to push the WLAN config down to your users.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Stephen Rodriguez
Step 6
http://blogs.technet.com/b/networking/archive/2012/05/30/creating-a-secure-802-1x-wireless-infrastructure-using-microsoft-windows.aspx
HTH,
Steve
HTH,
Steve
George Stefanick
Apple and other devices are smart and for ease of use figures out the auth and encryption.
Windows 7 not so much. You need to push the profile down or manually configure ..
Is there any other L2 security method that wont require the configuration on client side ?
Sadly no unless you add or push a profile. We use Intel and have a profile on each device.
Abhishek Abhishek
Hello Vijay,
As per your query i can suggest you the following solution-
PEAP authenticates wireless LAN clients using only server-side digital certificates by creating an encrypted SSL/TLS tunnel between the client and the authentication server. The tunnel then protects the subsequent user authentication exchange.
Follow these steps-
1.Open wifi settings
From the Home screen, press the Menu button and then select 'Settings'
2.Open Wireless & Networks
Select 'Wireless & networks'
3.Enable WiFi
If 'Wi-Fi' is Off, Select 'Wi-Fi'
4.Enter WiFi settings
Enter Wi-Fi settings
Select 'Wi-Fi settings'
5.Add SSID manually
Scroll to the bottom of the screen and select 'Add Wi-Fi network'
Enter HC_Secure in the Name field
6.Set Security
Select 'Security' drop-down menu and select '802.1x Enterprise'
7.Authentication (Phase 2)
Select 'Phase 2 authentication' drop-down menu and select 'MSCHAPV2'
Note: You may need to scroll down on the page to access the 'Phase 2 authentication' drop-down menu
8. Enter your Account
Enter your HC Network ID in the 'Identity' field and the password in the 'Wireless password' field
Note: You must scroll down on the page to access these fields
9.Save
Select the 'Save' button
Hope this will help you.
Hi Abishek ,
Thanks for the reply .  Actually i dont want to validate the serer site certifcate.And the problem is i dont want to configure these setttings in all the employee laptops  , which is very difficult for us . We dont want IT team support for configuring wireless settings on employees laptop .
When the employee connects to broadcasted SSID, laptop should automatically find the security settings of that SSID.
Please help.
Thanks ,
Vijay.
