Difference between Image 8.2 and 8.5 or 8.3 of WLC 8540.
rahulchauhan
Hi All,
Can anyone tell me the basic difference between these images and which one i need to upgrade to and why?
Patrick Richter
Hi rahulchauhan,
please review the "whats new" section at the release notes
8.5
https://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn85.html#whats_new_release_85b
8.3
https://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn83.html#pgfId-1534270
As i know 8.2 were a early feature release and no further releases planned.
To choose the right image review the TAC recommendation list.
https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html
And also compare your WLC, AP, MSE/CMX and ISE version using the following matrix to avoid incompatibilities.
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Best Regards
Patrick
Jonas Kalldert
Hello rahulchauhan,
The main difference between the versions are features and HW compability.
Here are the release notes for the versions you asked about:
8.2.170.0 https://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn82mr7.html
8.3.140.0 https://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn83mr4.html
8.5.135.0 https://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn85mr3.html
Cisco have marked 8.3 and 8.5 as recommended on the 8540. If your APs allow it I would go with 8.5.135.0 for the latest features and bug fixes. I have a couple of customers running 8.5 without any problems.
But it comes down to what features you need. Also always check the list of known bug so you dont trigger one in your deployment.
regards,
Jonas
**Don't forget to rate helpful posts**
