Difference Between Layer 2 Security and WPA & WPA2 Parameters
Hello Everyone, thank you everyone to read me again.
I have one questions about security WLAN configuration. I created one SSID when I configured the tab security I see this:
I'm not an expert how you can see but I thought that when you use WPA + WPA2 you will use an PSK to join the network.
I see I can use 802.1X in layer 2 security.
I don't really understand what the difference betwen this options. I mean if  I use 802.1X for layer 2 security I need to stablish a WEP KEY?
IF I use a WPA +WPA2 for layer 2 security and 802.1X for Auth Key Managment I need to use a Radius?
Exist any documentation about this options?
Espero que la información haya sido útil y si no tienes más preguntas recuerda cerrar el topic, seleccionando la respuesta como "Respuesta correcta"
**Please rate the answer if this information was useful***
**Por favor si la información fue util marca esta respuesta como correcta**
Scott Fella
Look at it this way.
WPA+TKIP
Uses pre shared key and is not supported by 802.11n
WPA2+AES
Also uses pre shared key and is supported by 802.11n
WPA+TKIP or WPA2+AES and 802.1x
Requires a radius server or the use of LDAP
Also requires a certificate
Server side certificate for PEAP and a server and client side certificate for EAP-TLS.
You also want to only use either WPA/TKIP or WPA2/AES, not both and don't mix and match.
-Scott
Scott Fella
WPA+TKIP
WPA2+AES
-Scott
Scott Fella
