difference in Lisences on Cisco PI 1.2
ammahend
can someone explain the difference between Lisence types on Cisco Prime Infra 1.2 as below
Base Lisence
Lifecycle management Lisence
compliance management lisence
Automated deployment Gateway
Assurance Management Lisence.
Thank you
-hope this helps-
Amjad Abdullah
Look into this:
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps6528/ps12239/guide_c07-714720.html
I think your post is not in the correct forum. better to move it.
Rating useful replies is more useful than saying "Thank you"
manjeets
Level 3
Level 3
Base License: Enables using a Cisco Prime Infrastructure management node (physical or virtual appliance). A single Base license is required for each management node and is a prerequisite for adding Cisco Prime Infrastructure feature licenses (Lifecycle and Assurance).
Lifecycle License: Provides access to the Lifecycle feature set, which includes device configuration management, software image management, basic health and performance monitoring, fault management, troubleshooting, and network client visibility. The Lifecycle license is based on the number of managed devices (for example, routers, switches, access points, and so on). Lifecycle licenses are available in bundle sizes of 25, 50, 100, 500, 1000, 2500, 5000, and 10,000 devices and can be combined as needed to achieve a total licensed device count.
manjeets
Level 3
Level 3
Assurance License: Provides access to the Assurance  feature set, which provides end-to-end network visibility of application  and service performance to help ensure end-user quality of experience.  The Assurance feature set also provides the ability to manage and  aggregate data and views across multiple Cisco Prime Network Analysis  Modules (NAMs). The Assurance license is based on the number of managed  NetFlow-enabled interfaces. Assurance licenses are available in bundle  sizes of 15, 50, 100, 500, 1000, and 5000 NetFlow-enabled interfaces.  The 15 interface license has a restriction that allows you to manage  only up to 5 NAMs, whereas the other Assurance license bundles do not  place a restriction on the number of NAMs that you can manage. The 15  interface license can only be used standalone and not combined with the  Lifecycle licenses. You need to purchase a 50 interface Assurance  license or larger to use with other Cisco Prime Infrastructure feature  licenses.
Automated Deployment Gateway License:  Provides the entitlement to deploy a separate gateway for use with the  Automated Deployment feature, where new devices can call in to the  gateway to receive their configuration and software image. The Automated  Deployment Gateway license is based on the number of gateway instances  you deploy. In the current release only a single gateway can be deployed  per Cisco Prime Infrastructure instance.
manjeets
Level 3
Level 3
Compliance License: Provides access to regulatory compliance reports based on common government and industry regulatory standards. The following standards are currently supported: PCI, HIPAA, CIS, DHS, DISA, NSA Cisco SAFE. Compliance licenses are based on the number of managed devices. Compliance licenses are available in bundle sizes of 25, 50, 100, 500, 1000, 2500, 5000, and 10,000 devices and can be combined as needed to achieve a total licensed device count. Lifecycle licenses are a prerequisite for using Compliance licenses. You should have the same number of Compliance licenses as you have for Lifecycle licenses. Note: This license type is currently used only with Cisco Prime LAN Management Solution 4.2. Corresponding compliance functionality will be in a later release of Cisco Prime Infrastructure.
