Showing results forĀ
Search instead forĀ
Did you mean:Ā
Disable Dynamic Arp inspection in Cisco Wireless controller 2500
sadhiqkp
We are facing a problem in Cisco WLC 2500 with ios 8.5. We need to disable DAI. Please let me know how to disable the DAI in  GUI or CLI
5 Replies 5
balaji.bandi
what kind of problem : check below and understand DAI  - Example :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/12-2/25ew/configuration/guide/conf/dynarp.html
BB
i didnt ask you for the explanation for DAI. I just need to disable DAI On wireless controller
The information that direct you solution that its WLC does not support. you can do on Switch if you like to. (Hope you able to understand the concept).
BB
 You may see DAI in 9800 which is IOS XE based but not in  2500 which is based in AIROS.
I think you need to disbale DAI in SW port that wlc connect to not in WLC.
