Disable Led on Access Point Autonomous
I need disable led on accesspoint autonomous cisco 2602e
Rasika Nayanajith
Try this & see
AAP1(config)#led display ?
  dim  Turn LED display dim.
  off  Turn LED display off.
Rasika
**** Pls rate all useful responses *****
5 Replies 5
Rasika Nayanajith
Try this & see
Rasika
Hi rasikanayanajith
Thanks for your request
This command apply for Cisco Access-Point 2602 but Do you know the command for Cisco Access-Point 3602e.
I tried apply this command and not work
Regards.
Does this 3602e is in Autonomous mode as well or is it managed by a WLC ?
If it is manged by WLC you have to do this via WLC
(WLC) >config ap led-state disable
If it is autonomous mode, let me know the code version to check & see
Rasika
Hi rasikanayanajith
All access-point are 2602e but had different IOS version. The command LED DISPLAY OFF is correct, but depend of IOS version.
Regards.
Hi, could you indicate the command to turn off the led on Cisco AIR-SAP2602I-A-K9 IOS Software, C3600 Software (AP3G2-K9W7-M), Version 15.2(2)JA, RELEASE SOFTWARE (fc1)? Thanks in advance.
