Disabling 2.4Ghz on a SSID
Hello
I have a controller CISCO 5520 and AP 1832i
I want to disable the 2.4Ghz for a professional SSID (automatic handling trolley)
I saw that for an SSID we could choose 802.11a
but by doing that I can not connect ...
If I put on all, I can connect.
Another question, putting 802.11a only
has all the features of the 802.11n and 802.11ac protocols
Rasika Nayanajith
What do you mean by that ? once you do this, you cannot see SSID ? or you can see, but client does not connect ?
Yes, above will include 802.11n & 11ac support in 5GHz band
Rasika
Tanks for reply
When i say i can't conect
I see the ssid but connection failed
Windows says can't connect
802.1a option only permit device which its support only 802.11bgn ac ?
Change this SSID to open authentication.  Can the trolley connect or not?
