disconnect problem
yatisengineer
Community Member
Hi;
I have 11 1242AG access points. I have two ssids on them. One is for guests. The other one is for corporate use. I used microsoft ias for active directory authentication. It works well but sometimes users fall to "limited connectivity" situation(without changing their place). This is seen for each ssid.
Guest ssid: unsecure (wpa with radius is the AP itself)
corporate ssid: Show_Ap (eap authentication over active directory IAS)
What can cause this issue, is there any idea? I sent some syslog as attachment..
diro
Level 6
Level 6
Are their neighbour ap's giving you interference?
There is no interference, i've tested it before.
