Displaying Radio Channel Frequency
williamsryan
Hi All,
Is there anyone who can tell me if there is command that I can use within the IOS on an access point (1131) that will display what radio channel it is using?
At the moment I am having to use NetStumbler to identify what channels access points are using, it would be so much easier if there was a command along the lines of 'show interface dot11radio 0 channel'
Ryan
jeromehenry_2
Level 3
Level 3
Yes, it's easy:
show controllers dot11Radio 0
hope it helps
jerome
jeromehenry_2
Level 3
Level 3
Yes, it's easy:
hope it helps
jerome
Thanks, that has done the trick.
I have spent ages trying to find out what the command was. I knew there had to be one somewhere.
Thanks again.
