Displaying Wrong SSID
lenkasurat
Level 3
Level 3
Hello Experts,
I have configured couple of sites with Flexconnect AP. all the sites are working fine and no issues.
But I see a strange issue for a new site where I see E.g. I have configured ssid = abc, on the site I see is displayed SSID = (wireless abc) did not understand the reason!!
rest all 45 sites are working fine and also the ssid display abc only. Need urgent help!!
Any suggestion or troubleshooting guide will be appreciated.
Thanks in advance!
Rasika Nayanajith
Did you check this with different type of end devices ? If all of them seen that as SSID, you may need to check your configuration again.
Rasika
