DMZ Anchor DHCP Issue
scott.samra
I recently configured a DMZ Anchor controller and both control and data paths are showing 'up'.  When a user connects the the WLAN they are receiving an IP address from the foreign controller interface rather than the DMZ anchor which is configured for an internal DHCP server.  I have the guest WLAN configured with the management interface which has the controller's IP as the DHCP server.
Any ideas?
Thank you,
Scott
Ashish Chandra
Could you please try enabling DHCP Proxy on Anchor Controller:-
 Controller > Advanced > DHCP > Enable DHCP Proxy
When DHCP proxy is enabled on the Cisco WLC, the Cisco WLC unicasts DHCP requests from the client to the configured servers. Consequently, at least one DHCP server must be configured on either the interface associated with the WLAN or the WLAN itself.
Thank you Ashish...
DHCP Proxy is enable on both the Anchor and Foreign controllers.  I am working to get both controllers on the same version of code to see if that helps.
