Does anyone know of a way to tell Prime Infrastructure how often to poll devices
Rob Johnson
Can PI be configured to poll devices every 5, 10, 15 minutes via a global setting?
All I can find are retry, timeout and backoff algorithm settings.
Let me know.
thanks, rob
You can navigate to Design > Monitoring Configuration > Features >  Metrics > Interface Health (shown below). Follow the same methodology to  change the polling interval as mentioned for Device Health. You can see how  interface availability is changed to every minute.
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps6528/ps12239/deployment_guide_c07-721232.html
Hafed Ait Elhaj
try This
Step 1 Select Monitor > Performance Settings > Setup > Automonitor from the menu.
The Auto Monitoring details window appears.
Step 2 Select one of the following values available in the Polling Interval drop-down list to modify the polling interval:
1 Minute
5 Minutes
15 Minutes
30 Minutes
To exclude the group from auto-monitoring, select Don't Monitor from the drop-down list.
Step 3 Click Apply
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.2/user/guide/lms_monitor/mnt-perf.html
Hafed,
this is how to do it in LMS.
I'm trying to figure out how to do it in Prime Infrastructure...
Hafed found this::
Interface polling can be very quickly enabled by using a predefined monitoring  template. You can navigate to Design > Monitoring Configuration > Features  > Metrics > Interface Health (shown below). Follow the same methodology to  change the polling interval as mentioned for Device Health. You can see how  interface availability is changed to every minute. 11:56 AM
Good find Hafed!!!
