Does C9124AXI-E -require a 9800 controller in bridge mode
robert.jubb
Level 2
Level 2
Does C9124AXI-E -require a 9800 controller in bridge mode?
jagan.chowdam
Hi Robert,
AP for outdoor environments, with external antennas
C9124AXE-x
The AP has 6 external antenna ports and contains a 2.4–GHz and 5–GHz radio with an option to configure in centralized and Flexconnect mode.
This is a stand alone unit that can be wall, pole or tower mounted. It can also operate as a relay node for other access points that are not directly connected to a wired network.
Cisco 9124AXE in EWC (Embedded Wireless Controller) mode (SKU C9124AXE-EWC-x) doesn't require a 9800 WLC.
Refer the post for
https://community.cisco.com/t5/wireless/wireless-bridge-between-two-c9124axe/td-p/4847399
Jagan Chowdam
/**Pls rate useful response**/
