Does Cisco Maintain a Hardware Compatible List?
Trinh Nguyen
Level 2
Level 2
I am looking for solution to replace our current enterprise wireless with Cisco.  Does Cisco have a Hardware Compatible List (list of all wifeless devices work best with Cisco controller and thin APs)
George Stefanick
This is not a hardware matrix, but rather a software matrix. Just wanted to pass this along incase you needed it ...
http://www.google.com/url?sa=t&source=web&cd=1&sqi=2&ved=0CCAQFjAA&url=http%3A%2F%2Fwww.cisco.com%2Fen%2FUS%2Fdocs%2Fwireless%2Fcontroller%2F4400%2Ftech_notes%2FWireless_Software_Compatibility_Matrix.pdf&rct=j&q=wireless%20solutions%20software%20comp...
Surendra BG
Here is the link which gives you the depth info regarding the devices tha twe have for Enterprise network design!!
http://www.cisco.com/en/US/prod/wireless/wireless_for_enterprise.html
lemme know if this answered your question..
Surendra
Please dont forget to rate the posts which answered your question and mark it as answered or was helpfull
Surendra BG
George Stefanick
Thank you for the rating
