as far i know if i try to login to the domain with wireless connection in a laptop instead of wired i get the error message that domain not available, this is basically because you are not connected the network .i.e your wireless card only connects to the network only once you login.unlike the wired connection it connects to the network even before login. if you have already logged in through wired connection and try login wirelessly it takes the credentials from the cache. can some one please suggest me is there any thing we can do to overcome this.
thanks
Karthik
