03-08-2019 04:44 AM - edited 07-05-2021 10:01 AM
Hello
same mobile don't see SSID and some mobile see SSID and we have two fortigate 200D and controlle 3504 and 26 ap
SO , i need a help that expain why same mobile don't see SSID !!!
what i can to check in fortigate or controller ?,,,,,,,
thanks
Solved! Go to Solution.
03-08-2019 04:55 AM
SOME ONE tell me the problem is in mobile or fortigate 200d or controller ???
because some see SSID and other mobile don't see SSID !! language frensh or english for this SSID
03-08-2019 05:11 AM
03-08-2019 05:27 AM
03-08-2019 06:11 AM
sumsung , Huawai , OPPA A3S ...actually
so what doyou thinks this problem . for mobile or fortigate or controler !!
lease urgeeeeeent i need a help
03-08-2019 06:12 AM
03-08-2019 06:32 AM
03-08-2019 08:01 AM
May be these devices don’t support 5ghz !!
dont forget to rate helpful posts
03-08-2019 04:55 AM
03-08-2019 05:11 AM
03-08-2019 05:27 AM
03-08-2019 06:11 AM
03-08-2019 06:12 AM
03-08-2019 06:32 AM
03-08-2019 08:01 AM
03-08-2019 09:43 AM
Yes , it is ok i enbaled band in controler 2.4 ghz so all mobile see SSID in Tunisia
so
