Dopod PDA connect to 4402+1130 problem
bbxie
Level 3
Level 3
Anybody knows what should be tuned for connect a Dopod PDA to 4402+1130?
currently my customer configured a wlan using WPA-PSK/TKIP, laptop can join it without problem, but a Dopod PDA can't.
4402 version: 4.2.61
Dopod PDA:TRIN100(Windows Mobile ProfessionalCE OS 5.2.1437)
I asked customer to use "debug mac" to capture packet and found the WLC can receive PDA's probe-request, but never sent back probe-response, the PSK and SSID are correctly configured at the PDA.
I guess there maybe have some mis-match on DTIM/Preamble/Aironet IE, however I don't know what should be for Dopod, I'd like to get some idea on these before I go onsite to do troubleshooting, any feedback will be appreciated!
didyap
Level 6
Level 6
Try the following steps. It may help you
-Create a test SSID with no security and allow it to be broadcast see if the PDA can see the WLAN and connect
-Hide the SSID, see if the PDA can still connect
-Create a basic 40bit wep key and allow shared key authentication, see if 2 x PDA's can connect using this key...
-Finally, set the WEP key to "not set" and move down to the WPA option. Set both WPA 1 and 2 to TKIP (not AES), then try this reversed. try and make the key simple like "abc123"
