dot11 activity-timeout
john.wright
Level 6
Level 6
I read in the documentation that AP's by default are set to 60 second activity-timeout.
What does that mean in terms of the client association? Does the client disassociate after 60 seconds? What happens after the 60 second timer expires?
I am researching why many users across our campus are complaining that they lose connection from time to time.
I have autonomus 1141N with 12.4(25d)JA1.
Viten Patel
can you point out to the doc which states that? are the clients getting disconnected at regular intervals or randomly?
I think he means this.
Use the dot11 activity-timeout  global configuration command to configure the number of seconds that  the access point tracks an inactive device (the number depends on its  device class). The access point applies the unknown device class to all  non-Cisco Aironet devices.
dot11 activity-timeout { [ client-station | repeater | bridge | workgroup-bridge | unknown ]  [ default <1 - 100000> ] [ maximum <1 - 100000> ] }
Syntax Description
client-station, repeater, bridge, workgroup- bridge
Specify Cisco Aironet device classes
unknown
Specifies unknown (non-Cisco Aironet) device class
Specifies the activity timeout value that the access point uses when a  device associates and proposes a zero-refresh rate or does not propose a  refresh rate
Specifies the maximum activity timeout allowed for a device regardless  of the refresh rate proposed by a device when it associates
Defaults
Table 2-4 lists the default activity timeouts for each device class. All values are in seconds.
Table 2-4     Default Activity Timeouts
Device Class
Default Timeout
unknown
60
client-station
1800
repeater
28800
bridge
28800
workgroup-bridge
28800
