07-03-2008 11:22 AM - edited 07-03-2021 04:07 PM
I've a vpn router with a dot11radio card installed. Clients on the wireless network are not able to get url names resolved. They can get to the page by using the ip address in the browser but can't get out otherwise so we know it's a dns issue. I've added the ISP's dns servers to the wireless dhcp pool and also taken them out but nothing helps. Thanks for any assistance to resolve this issue. The sanitized config file is attached.
Solved! Go to Solution.
07-03-2008 05:38 PM
If you remove your ACL's does it work, if not then try a public DNS like 4.2.2.1, 4.2.2.2.
Here is a link... scroll down to like the 5th thread:
http://forum.iopus.com/viewtopic.php?p=4230
07-03-2008 01:40 PM
I see that you have a dhcp pool for the lan. Is users on the lan okay?
07-03-2008 05:20 PM
No problems on the LAN which uses the company's DNS server. However, the wireless network by design doesn't haven't access to the corporate network and must use the ISP's DNS.
07-03-2008 05:38 PM
07-07-2008 06:56 AM
The only ACLs are for NAT and VPN. The wireless network goes directly out to the Internet and does not need VPN connectivity and this entry "access-list 110 permit ip 192.168.yy.0 0.0.0.255" any should allow NAT. The wireless network is 192.168.yy.0/24.
I'll try the public DNS addresses. Thanks.
07-07-2008 07:23 AM
Thanks very much for your help!!! Looks like the public DNS fixed the issue. I'll inform the ISP.
07-07-2008 07:27 AM
Good to know.... I have issues with Comcast's DNS at home, so I end up using one of those on the list. Usually Verizon's....
