Download and upload speed per ssid in air-sap2602.
waqas sardar
Dear team,
How to limit the download and upload speed per ssid in air-sap2602 ?
SSID =5MB download + 1upload
SSID= 30MB download + 5upload
Scott Fella
Waqas,
On autonomous access points you can't really limit or control the upload and download. This feature is available on a Unified Wireless Architecture using a WLC. Your best bet if your devices are in the same subnet is maybe controlling bandwidth from your layer 3 or FW.
-Scott
Agree with Scott, you can't do any thing on the AP level for this.
Traffic shaping & Policing at your L3 switch for each vlan is some options you should explore. Again this is depend on the hardware/software version you are running on the switch & can be configured in certain direction only. (shaping egress & policing ingress)
Rasika
**** Pls rate all useful responses ****
we are  using cisco 1941 with EHWIC-D-8ESG-P .
How i can configure Download and upload speed per ssid ?
If you need help with traffic shaping, you should post your question on the rLAN, Switching and Routing forum:
https://supportforums.cisco.com/community/netpro/network-infrastructure/switching
You can also look for examples by searching Configure 1941 traffic shaping:
http://www.cisco.com/en/US/docs/ios/12_2/qos/configuration/guide/qcfgts.html
http://www.cisco.com/en/US/docs/ios/12_2/qos/configuration/guide/qcfcbshp.html
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
