DTLS connection was closed
Mohammed
Hi All,
I need your help. I reset a AP via our WLC as the 80211b/g/n radio was operation status down, but the AP has not joined the WLC again, its got the same DHCP ip address, but here is the error msg ive got;
(Cisco Controller) >*spamApTask2: Nov 10 19:37:25.887: 00:1f:c9:46:84:00 Discarding non-ClientHello Handshake OR DTLS encrypted packet from  10.108.12.14:5060)since DTLS session is not established
5 Replies 5
Mohammed
*spamApTask3: Nov 10 19:39:45.978: 00:1f:c9:46:84:00 Deleting AP 10.108.12.14 which has not been plumbed
*spamApTask3: Nov 10 19:39:45.983: 00:1f:c9:46:84:00 DTLS connection was closed
*spamApTask3: Nov 10 19:39:45.983: 00:1f:c9:46:84:00 Discarding non-ClientHello Handshake OR DTLS encrypted packet from  10.108.12.14:5061)since DTLS session is not established
*spamApTask2: Nov 10 19:42:06.027: 00:1f:c9:46:84:00 Deleting AP 10.108.12.14 which has not been plumbed
*spamApTask2: Nov 10 19:42:06.031: 00:1f:c9:46:84:00 DTLS connection was closed
(Cisco Controller) >dis   debug *spamApTask2: Nov 10 19:42:06.031: 00:1f:c9:46:84:00 Discarding non-ClientHello Handshake OR DTLS encrypted packet from  10.108.12.14:5060)since DTLS session is not established
*spamApTask3: Nov 10 19:44:26.193: 00:1f:c9:46:84:00 Deleting AP 10.108.12.14 which has not been plumbed
*spamApTask3: Nov 10 19:44:26.197: 00:1f:c9:46:84:00 DTLS connection was closed
*spamApTask3: Nov 10 19:44:26.197: 00:1f:c9:46:84:00 Discarding non-ClientHello Handshake OR DTLS encrypted packet from  10.108.12.14:5061)since DTLS session is not established
(Cisco Controller) debug>disable-all
(Cisco Controller) debug>exit
(Cisco Controller) >show clok?
(Cisco Controller) >show clok    time
Time............................................. Mon Nov 10 19:44:42 2014
Timezone delta................................... 0:0
Timezone location................................ (GMT) London, Lisbon, Dublin, Edinburgh
NTP Servers
    NTP Polling Interval.........................     86400
     Index     NTP Key Index     NTP Server      NTP Msg Auth Status
       1              0         10.96.75.61       AUTH DISABLED
(Cisco Controller) >sd  show dtls connections
       AP Name         Local Port        Peer IP        Peer Port                Ciphersuite
 COMPANY-sw_brighton-5a   Capwap_Ctrl    10.108.12.21       1249           TLS_RSA_WITH_AES_128_CBC_SHA
 COMPANY-sw_brighton-2a   Capwap_Ctrl    10.108.12.25       1256           TLS_RSA_WITH_AES_128_CBC_SH
                       Capwap_Ctrl    10.108.12.14       5060           < Connection not established or unknown >
 COMPANY-sw_un4-gap4      Capwap_Ctrl    10.114.27.21      33214           TLS_RSA_WITH_AES_128_CBC_SHA
 COMPANY-sw_lon-bup-7ap   Capwap_Ctrl    10.100.27.24       5942           TLS_RSA_WITH_AES_128_CBC_SHA
 COMPANY-sw_lon-bup-7ap   Capwap_Ctrl    10.100.27.22       5965           TLS_RSA_WITH_AES_128_CBC_SHA
 COMPANY-sw_lon-bup-7ap   Capwap_Ctrl    10.100.27.21       5935           TLS_RSA_WITH_AES_128_CBC_SHA
 COMPANY-sw_un3-1ap4      Capwap_Ctrl    10.114.27.16      33259           TLS_RSA_WITH_AES_12
Ive also shutdown and re-enabled the switchport of the AP, still the same thing
Is it possible to get AP console output while your power cycle it ?
Rasika
Hi Rasika,
Thank you for your reply,
Unfortunately I unable to provide the out from the AP console, as the AP is in another city onsite on the wall.
On the WLC under Statistics and AP join it say the AP not joined.
Last AP Join
Received Discovery request and sent response
Received Config request and sent response
Last Error Summary
Last AP Disconnect Reason: AP found primary WLC in primary discovery response
ive fixed, I sent one of my colleague to site and got him to plug out the switchport and put it back in and it worked fine.
Thank you
