Need Your Help 5508 WLC works unnormally
Dears,
We have 2 WLC 5508, one of them is Active and other on is in Standby,  we have a strange issue, sometimes wireless signal from AP(2602) shows as
AD-HOC on Laptops, there is no error or something WLC shows us, what can be the reason, we using 7.4.100.0 Firmware
Another issue when i testing High Availiability, i turn off Active, some APs resetting and after 2-3 minutes again register on WLC
Is that firmware or what ?
Please help
2 Accepted Solutions
7.4.100.0 is NOT a stable code at all... Highly recommended to move out of it.. go for 7.4.121.0 . Below list few bugs we encounter with this code.
http://mrncciew.com/2013/02/10/day-0-with-wlc-7-4-code/
Rasika
**** Pls rate all useful responses ***
Leo Laohoo
I agree with Rasika.
Either upgrade to 7.4.121.X or 7.6.130.X.  I don't even want to bother troubleshooting anything with this version of firmware currently being used.
7 Replies 7
I can provide any info you will need
Rasika
I will update it and will tell you the results
At least 4 days i upgraded WLC, it is working stable at this moment
That's sounds like "issue is fixed". 4 days stability is good indication for the same.
Anyway monitor it for long & let us know if any issues
Rasika
Leo Laohoo
Upgraded to 7.100.121.x, now it works normal, im monitoring it via logs and debugging
thank you
