Dual band extension antenna cables (AIR-ANT2566P4W-R)
Joeri De Winter
I want to install some AIR-ANT2566P4W-R antennas outdoor against the wall, the 2602e access points will be mounted on the interior side of the wall, altough the wall is 30cm thick, so I need some antenna extension cables.
What type of coax extension cables would be recommended?
many thx
George Stefanick
I would go with a high LMR, like 600. The ends will be rptnc. Here is a Cisco reference guide ..
http://www.cisco.com/en/US/prod/collateral/wireless/ps7183/ps469/product_data_sheet09186a008008883b.html
I could only found the antenna extension cable with tnc connector.
However the antenna I use is N connector (AIR-ANT5180V-N &
AIR-ANT2480V-N), is cisco have any extension cable with N connector? or adaptor for it?
thank you.
