Dynamic AP Management
torstensson
Frequent Visitor
Frequent Visitor
I just got have a general question regarding Cisco WLC function. In the Web GUI under "Controller"->"Interfaces" there is a column namned "Dynamic AP Management", the options here seems to be "Enabled", "Not Supported" or Disabled". What exactly does "Dynamic AP Management" mean?
//Lars-Ove
Lars
pieterh
this is an interface that the controller can use to communicate with AP's.
an AP needs to discover this address using one of the available methods before it can register to the controller.
Normally you only use one AP-manager interface.
But i recall there is a maximum to the number of AP's that can register on a single interface,
that could be a reason to use multiple.
