Dynamic routing protocols over wireless.
grapeola
Community Member
Hello all,
Are there any issues with running dynamic routing protocols through two access points (1240AG) bridging two LANs that are presumably currently setup with a dynamic routing protocol?
Patrick
scottmac
Level 11
Level 11
There shouldn't be.
They are acting as bridges ... so no need for a routing protocol in the common broadcast domain.
Unless you have some flavor of broadcast / multicast control in-place, it should pass the traffic without issue.
Good Luck
Scott
