Dynamic vlan assignment with single SSID
g.peart
Level 3
Level 3
Hi All,
I have 300 APs deployed  and  concurrent client associations that number 3000+ daily
at the moment I have a single subnet for all users, there is no authentication just a click through
page with email entry to gain access.
The APs are assigned to groups based upon the building zone they are in, is it possible to
assign a vlan based upon the AP the user is associated to but still only broadcast a single SSID.
TIA
Viten Patel
You can assign dynamic vlan for 802.1X authentication using aaa override from RADIUS server.
In your case, since it is webconsent ssid you can use AP groups to put clients on differnt vlans per the AP group
Viten Patel
