EHWIC-4G-LTE- V Card Limits
GK
I have a EHWIC-4G-LTE-V Card runnning in a 2911 Router - there is a Cell Booster inline  between the outside antenna and the EHWIC Card. I'm getting :
Radio Information
Radio power mode = ON
Channel Number = I left this blank for security reasons
Current Band = LTE
Current RSSI = -33 dBm
Current RSRP = -62  dBm
Current RSRQ = -11  dB
Current SNR = 10.6  dB
LTE Technology Preference = AUTO
LTE Technology Selected = LTE
This is pretty strong RSSI with the booster on - Can anyone tell me if there is a limit on the RSSI to this card?
Thanks for your replies.
Saurav Lodh
Level 7
Level 7
For every vendor , they have their own RSSI calculations and hence their own limit to RSSI value ( which is a sampled value) so , it varies. Mostly have 100, cisco cards have 100
This from Cisco :
For LTE on the EHWIC-4G-LTE-V card - best practices maximum RSSI should be -40 dBm and the minimum -90 dBm
The best RSRP(Reference Signal Received Power) value should be -23 dBm.
