Embedded Wireless Controller license
03300209
I'd like to know, on AP's EWC, whether still need lic as same as physical WLC. Thanks.
Arshad Safrulla
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-series-wireless-controllers/q-and-a-c67-743152.html#:~:text=Q.%C2%A0%20What%20are%20the%20licensing%20requirements%20for%20the%20Embedded%20Wireless%20Controller%20on%20Catalyst...
At the moment if the EWC is deployed independently licenses are not needed, but if you are planning for a distributed deployment model using DNAC you need AIR-DNA licenses. Please refer the above link for more info.
