Enable mode on 2112 WLC
mahesh18
Level 6
Level 6
Do we have enable mod eon 2112 WLC ?
Also if we need to access WAP from WLC how can we telnet or ssh?
MAhesh
2 Accepted Solutions
Saravanan Lakshmanan
No.
First you need to join the AP to WLC, WLC>>wireless>>AP click on the AP and select Advanced tab, there you can see telnet, ssh check box.
Amjad Abdullah
There is no enable/config modes in WLC because it does not run IOS.
You need to enable either SSH or telnet (or both) on the AP from the controller settings (Saravanan metnioned the exact location where to do that in his previous reply. Thanks Saravanan). After enabling that you can telnet or ssh as you want from whatever terminal that can reach the AP on the network. (default username and password for telnet/ssh is Cisco/Cisco. You can change that from the AP settings as well on the WLC).
Amjad
Rating useful replies is more useful than saying "Thank you"
5 Replies 5
No.
Amjad Abdullah
Amjad
Hi Saravanan and Amjad,
Many thanks for your replies.
sorry for late rating of post.
Mahesh
Hello Mahesh
Thanks for Rating.
Saravanan
manjeets
Level 3
Level 3
No.
