Enabling TPCv2 for location aware deployment
g.peart
Level 3
Level 3
Hi All,
I am deploying a WLAN to support location awareness and was wondering if I enable TPCv2
should I also change the DCA interval/status, quite a few posts have said not to enable TPCv2, but why ?
TIA
Shaoqin Li
Level 6
Level 6
TPCv2 is dedicated for some certain dense ap deployment to generally avoid co-channel interface. Do not use it till told by Cisco.
for most deployment v1 is recommended.
But how do know if and when to enable the function, in short what does it actually do to the RRM function
